Component: TTI TG5011 Signal Generator (3rd Party Equipment/Tools)
Version 0.2 (Development)
Category 3rd Party Equipment/Tools
Image TTI TG5011 Signal Generator component
TTi TG5011 50 MHz Signal Generator
This component does not contain any downloadable macros
Simulation macro reference
NOISADD
Select <ON> to add the noise to the output waveform and <OFF> to remove the noise from the output waveform.
0 = ON, 1 = OFF.
BOOL Noise
Add/remove the noise to/from the output waveform (0 = ON, 1 = OFF).
PULSSYMM
Sets the pulse waveform symmetry to <nrf> %.
(Lower limit: 0 - Upper limit: 100)
FLOAT Symmetry
Sets the pulse waveform symmetry in percent. (0 - 100)
BSTPER
Sets the burst trigger period to <nrf> seconds.
(Lower limit: 1us - Upper limit: 500s).
FLOAT Seconds
Duration of the burst trigger period in seconds.
MODAMDEPTH
Sets AM waveform depth to <nrf> %.
(Lower limit: 0% - Upper limit: 120%).
FLOAT Frequency
Sets AM waveform depth in percent (%) (0 - 120).
WAI
Wait for Operation Complete true. As all commands are fully executed before the next is started this command takes no additional action.
This macro has no parameters
ARB3DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB3.
STRING
MODFMFREQ
Sets FM waveform frequency to <nrf> Hz.
(Lower limit: 1uHz - Upper limit: 20kHz).
FLOAT Frequency
Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODFSKSRC
Sets FSK waveform source to;
0 = INT, 1 = EXT.
BOOL Source
Sets FSK waveform source (0 = INT, 1 = EXT).
MODPWMDEVSYM
Sets PWM deviation to <nrf> %.
BYTE Deviation
Sets PWM waveform deviation in percent. (?)
SWPBEGFREQ
Sets the sweep start frequency to <nrf> Hz
(Lower limit: 1uHz - Upper limit: 100kHz)
FLOAT Frequency
Sets the sweep start frequency in Hertz(Hz) (1uHz - 100kHz).
PER
Sets the waveform period to <nrf> sec.
(Lower limit: 20ns - Upper limit: 1Ms)
FLOAT Period
Duration of the waveform period in seconds (20ns - 1Ms).
BEEPMODE
Set beep mode to;
0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR.
BYTE Mode
Sets the beep mode (0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR).
ARBDEF
Sets user specified waveform name <cpd2> and waveform point interpollation state <cpd3> of arbitrary waveform memory location <cpd1>.
STRING Name
Specified waveform name
STRING State
Waveform interpolatino state
STRING Location
Waveform memory location
SWPTRGSRC
Sets the sweep trigger source to;
0 = INT, 1 = EXT, 2 = MAN.
BYTE Source
Set the sweep trigger source (0 = INT, 1 = EXT, 2 = MAN).
PULSPER
Sets the pulse waveform period to <nrf> sec.
(Lower limit: 20ns - Upper limit: 1Ms).
FLOAT Period
Duration of the pulse waveform period (20ns - 1Ms).
CALVALRet
Returns the value from level calibration steps.
UINT
WAVELVL
Sets the output waveform level to <nr1> %.
(Lower limit: 50 - Upper limit: 100)
FLOAT Percent
Sets the output waveform level in percent (50 - 100).
MODFMSHAPE
Sets FM waveform shape to:
0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1,
11 = ARB2, 12 = ARB3, 13= ARB4.
BYTE Shape
Sets FM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ZLOAD
sets the output load, which the generator is to assume for amplitude and dc
offset entries, to;
0 = OPEN or 1 - 10,000
INT Output
Sets the output load for amplitude and dc offset entires (0 = OPEN or 1 -10,000).
SWPENDFREQ
Sets the sweep centre frequency to <nrf> Hz.
(Lower limit: 1uHz - Upper limit: 50MHz.)
FLOAT Frequency
Set the sweep end frequency in Hertz(Hz) (1uHz - 50MHz).
AMPLRNG
Sets the amplitude range to;
0 = AUTO, 1 = HOLD.
BOOL Range
Sets the amplitude range (0 = AUTO, 1 = HOLD).
ARB1Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
UINT
ARB2DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB2.
STRING
SYNCOUT
Sets the sync output to;
0 = ON, 1 = OFF.
BOOL Sync
Enable/disable sync output (0 = ON, 1 = OFF).
SRE
Set the Service Request Enable Register to <nrf>.
BYTE Status
FREQ
Set the waveform frequency to <nrf> Hz.
(Lower limit: 1uHz - Upper limit: 50MHz).
FLOAT Frequency
Sets the waveform frequency in Hertz(Hz) (1uHz - 50MHz).
CALIBRATION
Sets the calibration mode to <START>, <SAVE>, or <ABORT>. <nrf> represents the calibration password.
BYTE Mode
0 = START, 1 = SAVE, 2 = ABORT
ULONG Password
Calibration password
DCOFFS
Sets the dc offset to <nrf> Volts.
(Lower limit: -4.500 Vdc - Upper limit: 4.500 Vdc).
FLOAT DCOffset
Sets the dc offset in Volts(Vdc) (4.500 Vdc - 4.500 Vdc).
PRE
Sets the Parallel Port Enable Register to the value <nrf>.
BYTE Status
Set register value 0-255
PULSFALL
Sets the pulse waveform negative edge to <nrf> micro seconds.
(Lower limit: 5ns - Upper limit: 99.9ns).
FLOAT Fall
Sets the pulse waveform negative edge in micro seconds (5ns - 99.9ns).
MODAMSRC
Sets AM waveform source to;
0 = INT, 1 = EXT.
BOOL Source
Sets AM waveform source (0 = INT, 1 = EXT).
SWPMKRFREQ
Sets the sweep marker to <nrf> Hz.
(Lower limit: 10kHz - Upper limit: 100kHz).
FLOAT Frequency
Set the sweep marker in Hertz(Hz) (10kHz - 100kHz).
AMPUNIT
Sets the amplitude units to;
0 = VPP, 1 = VRMS, 2 = DBM.
BYTE Units
Sets the amplitude units (0 = VPP, 1 = VRMS, 2 = DBM).
ESRRet
Returns the value in the standard event status register in <nr1>
BYTE
QERRet
Query and clear error register
BYTE : Returns the instruments address
MODHOPFREQ
Sets HOP frequency to <nrf> Hz.
FLOAT Frequency
Sets HOP frequency in Hertz(Hz) (1uHz - 50MHz).
SWPTIME
Sets the sweep time to <nrf> seconds
FLOAT Seconds
Set the sweep time in seconds.
PRERet
Returns the value in the Parallel Poll Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
BYTE
PULSWID
Sets the pulse waveform width to <nrf> sec.
FLOAT Seconds
Sets the pulse waveform width in seconds (20ns - 1Ms).
AMPL
Sets the amplitde to <nrf> in the units as specified by the AMPUNIT command.
(Range = 10mVpp - 10Vpp)
FLOAT Amplitude
Sets the amplitude (10mVpp - 10Vpp). Units specificied by AMPUNIT command.
ARB4Ret
UINT
ARBLOAD
<cpd> sets the output waveform type to <DC>,<SINC>, <EXPRISE>,<LOGRISE>,<RAMPUP>,<RAMPDN>, <TRIANG>,<SQUARE>,
<ARB1>,<ARB2>,<ARB3>, <ARB4>, <"USERNAME1">, <"USERNAME2">, <"USERNAME3">, <"USERNAME4">.
STRING Type
Waveform Type
MODPOLFSK
Sets FSK trigger slope to;
0 = POS, 1 = NEG.
BOOL Slope
Set FSK trigger slope (0 = POS, 1 = NEG).
PULSEDGE
Sets the pulse waveform edges (positive and negative edge) to <nrf>
micro Sec. Value zero sets to the minimum value allowed
(Lower limit: 5ns - Upper limit: 40us).
FLOAT Edges
Sets the pulse waveform edges in micro seconds (5ns - 40us).
ESERet
Returns the value in the Standard Event Status Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
BYTE : Returns the value in the standard event status enable register
MODPWMDEVWDT
Sets the PWM waveform deviation to <nrf> sec.
FLOAT Sec
OUTPUT
Sets the output to;
0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT.
BYTE SetOutput
Set the output. (0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT).
SLVRST
Sets the SLAVE generator ready to be synchronised
SQRSYMM
Sets the square waveform symmetry to <nrf> %.
(Lower limit: 20 - Upper limit: 80)
FLOAT Symmetry
Sets the square waveform symmetry in percent (20 - 80).
MODFSKRATE
Sets FSK rate to <nrf> Hz.
(Lower limit: 2mHz - Upper limit: 100kHz).
FLOAT Rate
Sets FSK rate in Hertz(Hz) (2mHz - 100kHz).
SWPMODE
Sets the sweep mode to <CONT> or <TRIG>.
0 = CONT, 1 = TRIG.
BOOL Mode
Set the sweep mode (0 = CONT, 1 = TRIG).
BST
Sets the burst mode to;
0 = <OFF>, 1 = <NCYC>, 2= <GATED>, 3 = <INFINITE>.
BYTE MODE
Sets the burst mode (0 = OFF, 1 = NCYC, 2 = GATED, 3 = INFINITE).
MODPWMSHAPE
Sets PWM waveform shape to;
BYTE Shape
Sets PWM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
SYNCTYPE
Sets the sync type to;
0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER.
BYTE Type
Set the sync type (0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER).
LOLVL
Sets the amplitude-low-level to <nrf> Volts.
(Lower limit: 5.000 V - Upper limit: -0.010 V).
FLOAT LowLevel
Sets the amplitude-low-level in Volts(V) (-5.000 V - -0.010 V).
SAV
Saves the complete instrument setup to the setup-file named <nrf>
BYTE StoreLocation
Memory location of register (0-9)
ARBDCOFFS
Sets the arbritary dc waveform offset to <nrf> volts.
FLOAT OffsetVoltage
Set the offset voltage
TRG
This command is the same as pressing the TRIGGER key.
ARB1DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1.
STRING
CLKSRC
Sets the clock source to;
0 = INT, 1 = EXT.
BOOL Source
Sets the clock source (0 = INT, 1 = EXT).
MODAMSHAPE
Sets AM waveform shape to:
0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
BYTE Shape
Sets AM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
SWPTRGPOL
Sets the sweep trigger slope to;
0 = POS, 1 = NEG.
BOOL Slope
Set the sweep trigger slope (0 = POS, 1 = NEG).
PULSRISE
FLOAT Rise
Sets the pulse waveform positive edge in micro seconds (5ns - 99.9ns).
BEEP
Sound one beep.
SWPCNTFREQ
FLOAT Frequency
Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz).
ARB2Ret
UINT
BSTTRGSRC
Sets the burst trigger source to;
BYTE Source
Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN).
MODPWMFREQ
Sets PWM waveform frequency to <nrf> Hz.
FLOAT Frequency
Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
SWP
Sets the sweep to <ON> or <OFF>.
0 = ON, 1 = OFF.
BOOL Sweep
Enable or disable the sweep (0 = ON, 1 = OFF).
RST
Resets the instrument parameters to their default values.
RMPSYMM
Sets the ramp waveform symmetry to <nrf> %.
FLOAT Symmetry
Sets the ramp waveform symmetry in percent (0 - 100).
BSTCOUNT
Sets the burst count to <nrf> cycles, maximum 1048575 cycles.
LONG Count
Sets the burst count in cycles (1 - 1048575).
SWPMKR
Sets the sweep marker to <ON> or <OFF>.
0 = ON, 1 = OFF.
BOOL Marker
Enable or disable the sweep marker (0 = ON, 1 = OFF).
MODFMDEV
Sets FM waveform deviation to <nrf> Hz.
(Lower limit: 1uHz - Upper limit: 25MHz).
FLOAT Deviation
Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz).
PULSFREQ
Sets the pulse waveform frequency to <nrf> Hz
FLOAT Frequency
Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz).
RCL
Recalls the instrument setup contained in store <nrf>.
BYTE StoreLocation
Memory location (0-9)
ESESet
Sets the standard event status enable register to the value of <nrf>.
(Lower limit: 0 - Upper limit: 255)
BYTE Value
Enable the register to this value. (0 - 255)
LOCAL
Returns the instrument to local opertion and unlocks the keyboard.
ARBRESIZE
Changes the size of arbritary waveform <cpd> to <nrf>.
FLOAT Size
Size of waveform
STRING Waveform
Arbritary Waveform
CALSTEP
Step to the next calibration point.
LRN
Intall data from a previous *LRN? command.
MODPMFREQ
Sets PM waveform frequency to <nrf> Hz.
FLOAT Frequency
OPC
Sets the Operation Complete bit (bit 0) in the Standard Event Status Register. This will happen immediately the command is executed because of the sequential nature of all operations.
SWPSPNFREQ
Sets the sweep frequency span to <nrf> Hz.
(Lower limit: 1uHz - Upper limit: 50.25kHz).
FLOAT Frequency
Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz).
SRERet
Returns the value of the Service Request Enable Register in <nr1> numeric format.
BYTE
ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
BYTE Waveform
CLKSRRet
Returns the clock source <INT> or <EXT>.
BOOL : Returns the instruments address
MODPMSHAPE
Sets PM waveform shape to;
BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
UINT Waveform
HILVL
Sets the amplitude-high-level to <nrf> Volts.
(Lower limit: -0.490 V - Upper limit: 5.000 V).
FLOAT HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
MODPMDEV
Sets PM waveform deviation to <nrf> degrees.
(Lower limit: -360° - Upper limit: 360°).
FLOAT Degrees
Sets PM waveform deviation in degrees (-360 - 360).
MSTLOCK
Sends signal to SLAVE generator to get synchronised
WAVE
Sets the waveform type.
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
UINT Waveform
CALADJ
Adjust the selected calibration value by <nrf>
(Lower limit: -100 - Upper limit: 100).
FLOAT Calibrate
Adjust the selected calibration value (-100 - 100).
EERRet
Query and clear execution error number register.
STRING
STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
BYTE
ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
UINT Waveform
16 Bit binary number for arbitrary waveform.
ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
STRING
ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
BYTE Value
Value of register 0-255
MODAMFREQ
Sets AM waveform frequency to <nrf> Hz.
FLOAT Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODFMSRC
Sets FM waveform source to;
0 INT, 1 = EXT.
BOOL Source
Sets FM waveform source (0 = INT, 1 = EXT).
CLS
Clears status byte register of the interface.
MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
NOISLVL
Sets the output noise level to <nr1> %.
(Lower limit: 0% - Upper limit: 50%)
BYTE Percent
Sets the output noise level in percent. (0 - 50)
ADDRESSRet
INT : Returns the instruments address
LOCKMODE
Sets the synchronising mode to;
0 = MASTER, 1 = SLAVE, 2 = INDEP.
BYTE Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
BOOL : Returns true if the operation is a success, else false
LRNRet
Returns the complete setup of the instrument as a binary data block
INT
MOD
Sets modulation to;
0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
MODPMSRC
Sets PM waveform source to;
0 INT, 1 = EXT.
BOOL Source
Sets PM waveform source (0 = INT, 1 = EXT).
MODPWMSRC
Sets PWM waveform source to;
0 = INT, 1 = EXT.
BOOL Source
Sets PWM waveform source (0 = INT, 1 = EXT).
OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
SWPTYPE
Sets the sweep type to;
0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>;
1 = 1, 2 = 2, 3 = 3.
BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
ARB3Ret
UINT
BSTTRGPOL
Sets the burst trigger slope to;
0 = POS, 1 = NEG.
BOOL Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
BSTPHASE
Sets the burst phase to <nrf> degrees.
(Lower limit: -360 - Upper limit: 360)
FLOAT Degrees
Sets the burst phase in degrees (-360 - 360)
IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'.
The return parameter is TRUE when the IDN is successfully returned.
<- STRING ReturnIDN
This parameter may be returned back to the caller
STRING
SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
FLOAT Seconds
Set the sweep trigger period in seconds.
PULSDLY
Sets the waveform delay to <nrf> sec
FLOAT Sec
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name ComPort.
