Component: Serial EEPROM (24C32) (Storage)
Version 1.1 (Release)
Category Storage
Image Serial EEPROM (24C32) component
Serial (I2C) EEPROM component for 24C32 Can be added to a MIAC project to give read and write access to the internal non-volatile memory device (if fitted, depending upon model).
Read
Read and return the value of the EEPROM at the given address
UINT address
BYTE
Write
Write the given data value to the EEPROM at the given address
UINT address
BYTE data
Simulation macro reference
Device Address
This property is of type Unsigned integer and can be referenced with the variable name DEVICE_ADDRESS.
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
SDA
This property is of type Single digital pin and can be referenced with the variable name SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name SCL.
