Component: GLCD (ST7565R) Parallel (Displays: Graphical)
Revision as of 15:46, 16 February 2017 by BenR (talk | contribs) (XML import BR)
Version 1.4 (Release)
Category Displays: Graphical
This inherits from GLCD Base
Image GLCD (ST7565R) Parallel component
Graphical display component designed to work with the ST7565 type monochrome displays. Transfers data using an 8-bit digital data bus.
This component inherits downloadable macros from GLCD Base
ReadASCIILUT
Gets a byte of the embedded ASCII font data.
This call is provided by GLCD Base
BYTE pos_str
ASCII position -32 so A = 'A' - 32 = 33
BYTE count
Font column Ranging 0-4
BYTE
INT Number
UINT X
UINT Y
BYTE Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
BYTE Transparent
DrawLine
UINT X1
UINT Y1
UINT X2
UINT Y2
Plot
UINT X1
UINT Y1
DrawEllipse
UINT X
UINT Y
UINT XRadius
UINT YRadius
BYTE Transparent
BYTE Solid
SetDisplayOrientation
BYTE Orientation
BPlot
UINT X1
UINT Y1
Print
<- STRING Str
This parameter may be returned back to the caller
UINT X1
UINT Y1
BYTE Font
BYTE Transparent
ClearDisplay
This macro has no parameters
SetBackgroundColour
BYTE PixelColour
0=White, 1=Black
DrawCircle
UINT X
UINT Y
UINT Radius
BYTE Transparent
BYTE Solid
SetForegroundColour
BYTE PixelColour
0=White, 1=Black
DrawRectangle
UINT X1
UINT Y1
UINT X2
UINT Y2
BYTE Transparent
BYTE Solid
Simulation macro reference
This component inherits simulation macros from GLCD Base
INT Number
UINT X
UINT Y
BYTE Font
BYTE Transparent
DrawLine
UINT X1
UINT Y1
UINT X2
UINT Y2
Plot
UINT X1
UINT Y1
DrawEllipse
UINT X
UINT Y
UINT XRadius
UINT YRadius
BYTE Transparent
BYTE Solid
BYTE Orientation
BPlot
UINT X1
UINT Y1
Print
<- STRING Str
UINT X1
UINT Y1
BYTE Font
BYTE Transparent
ClearDisplay
SetBackgroundColour
BYTE Red
BYTE Green
BYTE Blue
DrawCircle
UINT X
UINT Y
UINT Radius
BYTE Transparent
BYTE Solid
SetForegroundColour
BYTE Red
BYTE Green
BYTE Blue
DrawRectangle
Draws a rectangle with the current foreground colour from pixel loaction X1, Y1 to pixel location X2, Y2.
UINT X1
UINT Y1
UINT X2
UINT Y2
BYTE Transparent
BYTE Solid
Pixel Height
This property is of type Signed integer and can be referenced with the variable name pixel_height.
Pixel Width
This property is of type Signed integer and can be referenced with the variable name pixel_width.
Monochrome
This property is of type True or false and can be referenced with the variable name monochrome.
Foreground Color
This property is of type Color picker and can be referenced with the variable name foreground_colour.
Background Color
This property is of type Color picker and can be referenced with the variable name background_colour.
Color Bit Depth
This property is of type Signed integer and can be referenced with the variable name colour_bit_depth.
Red Bit Depth
This property is of type Signed integer and can be referenced with the variable name red_bit_depth.
Green Bit Depth
This property is of type Signed integer and can be referenced with the variable name green_bit_depth.
Blue Bit Depth
This property is of type Signed integer and can be referenced with the variable name blue_bit_depth.
Data0
This property is of type Single digital pin and can be referenced with the variable name data0_pin.
Data Pin 0
Data1
This property is of type Single digital pin and can be referenced with the variable name data1_pin.
Data Pin 1
Data2
This property is of type Single digital pin and can be referenced with the variable name data2_pin.
Data Pin 2
Data3
This property is of type Single digital pin and can be referenced with the variable name data3_pin.
Data Pin 3
Data4
This property is of type Single digital pin and can be referenced with the variable name data4_pin.
Data Pin 4
Data5
This property is of type Single digital pin and can be referenced with the variable name data5_pin.
Data Pin 5
Data6
This property is of type Single digital pin and can be referenced with the variable name data6_pin.
Data Pin 6
Data7
This property is of type Single digital pin and can be referenced with the variable name data7_pin.
Data Pin 7
CS
This property is of type Single digital pin and can be referenced with the variable name chip_sel_pin.
Chip select pin
Reset
This property is of type Single digital pin and can be referenced with the variable name reset_pin.
Reset pin
A0
This property is of type Single digital pin and can be referenced with the variable name a0_pin.
Enable
This property is of type Single digital pin and can be referenced with the variable name enable_pin.
Enable pin used to clock data into the display
RW
This property is of type Single digital pin and can be referenced with the variable name read_write_pin.
Read Write pin to set the display data mode
Display Method
This property is of type Fixed list of ints and can be referenced with the variable name DisplayMethod.
Chooses which method to use when drawing to the gLCD component
The bitmap is the more common mode but may run slowly on some machines.
The point cloud should run faster but may use more memory.
