Component: Bitmap Drawer FAT (Displays: Graphical)
Author | Matrix TSL |
Version | 2.0 (Release) |
Category | Displays: Graphical |
Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to.
GetHeight
Returns the height of the loaded bitmap file in pixels.
- <- STRING Filename
- The filename of the bitmap we want to measure
GetWidth
Returns the width of the loaded bitmap file in pixels.
SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
- BYTE R
- BYTE G
- BYTE B
Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y.
Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
- Bitmap file to open from current directory on SD card 8.3 format
- UINT X
- X Axis coordinate, specifies the location of the left edge of the bitmap image
- UINT Y
- Y Axis coordinate, specifies the location of the top edge of the bitmap image
- BYTE Orientation
- 0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
- BYTE Transparency
- 0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
- BYTE Flip
- 0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Simulation macro reference
FAT Object
This property is of type Panel object and can be referenced with the variable name fat_obj.
FAT / SD Card Object to read the bitmap image from
gLCD Object
This property is of type Panel object and can be referenced with the variable name glcd_obj.
Graphical LCD Object to draw the bitmap image to
ColourDisplay
This property is of type True or false and can be referenced with the variable name Colour_Display.
Automatically detects if the graphical LCD object is colour or monochrome
