Component: Component Label (Advanced Shapes)
Revision as of 10:26, 9 May 2018 by BenR (talk | contribs) (XML import)
Author Matrix Ltd.
Version 1.2 (Release)
Category Advanced Shapes
Image Component Label component
Add a label to a component by including this component as a sub-component. The label will always face the viewer and move with its parent object. Text for the label is automatically read from the host component's name or any chosen property.
This component does not contain any downloadable macros
Simulation macro reference
SetTargets
Set the objects used to determine the label text and position.
HANDLE TextObject
Object that will provide the label text from its name or a property.
HANDLE BoundsObject
Object that will set the label position and bounding box.
ShowProperty
Sets the label to show a named property of the target object.
STRING Property
Name of the property to show.
SetPosition
Set where the label will appear relative to the object.
BYTE Position
Set the position - choose a preset from the list of constants, or 'Position XYZ to enter values below.
FLOAT X
X axis offset (only if 'Position_XYZ' selected for 'Position')
FLOAT Y
Y axis offset (only if 'Position_XYZ' selected for 'Position')
FLOAT Z
Z axis offset (only if 'Position_XYZ' selected for 'Position')
Hide
Hides the label.
This macro has no parameters
SetColor
Sets the color of the label using a single ULONG value - such as returned by
panel GetColor functions.
ULONG Color
Color to set the labels to.
SetColorRGB
Set the label color using separate red, green and blue color channels.
BYTE Red
Color parameter
BYTE Green
Color parameter
BYTE Blue
Color parameter
Update
Refresh the label after a change.
ShowName
Sets the label to show the target object's name
Show
This property is of type Fixed list of ints and can be referenced with the variable name show_label.
Decide what label to show...
None - no labels are displayed
Name - shows the component's name
Property - shows a property value of the component (a field for the property name will appear below)
Label target
This property is of type Panel object and can be referenced with the variable name label_target.
Set the object from which the label text will be taken.
If none is given, defaults to the parent of the label component.
Bounds target
This property is of type Panel object and can be referenced with the variable name bounds_target.
Set the object used to set the dimensions used for the positioning of the labels.
Auto Update
This property is of type True or false and can be referenced with the variable name label_auto_update.
Automatically update the label whenever the target's name or labelled property changes.
Use this sparingly, as it requires the component to regularly poll the component for changes!!
Color
This property is of type Color picker and can be referenced with the variable name label_color.
Color of the label text.
Background
This property is of type Color picker with transparency and can be referenced with the variable name label_bg_color.
Color for label backgroiunds - may be transparent.
Always On Top
This property is of type True or false and can be referenced with the variable name label_on_top.
Whether labels should always be draw on top of other objects.
Scale
This property is of type Floating point and can be referenced with the variable name label_scale.
Sets the basic size (text height) of the labels.
Follow Zoom
This property is of type True or false and can be referenced with the variable name label_auto_scale.
Whether labels get bigger and smaller when the panel is zoomed in and out.
Auto
This property is of type Fixed list of ints and can be referenced with the variable name label_position.
Attempt to automatically move the label to the side of the object. Choose a positive or negative offset in
any of the three axes. When 'off', the manual offsett values can be edited below.
