Component: Marking control (Advanced Shapes)
Revision as of 10:26, 9 May 2018 by BenR (talk | contribs) (XML import)
Version 1.1 (Release)
Category Advanced Shapes
Image Marking control component
A control to draw markings on any component
This component does not contain any downloadable macros
Simulation macro reference
DrawStripY
Draw the marks on the readout
Set up the position and range with SetRange() and SetSpan()
INT OffsetX
Offset to add to X
SetTarget
Sets the target image to draw on
ULONG Target
INT AreaX
The X area to draw on
INT AreaY
The Y area to draw on
BOOL AutoCreate
Set true to auto-create the graphic
DrawStripX
INT OffsetY
Offset to add to Y
BoundRange
Bounds a range to be between RangeStart and RangeEnd
FLOAT Range
The unbounded range
FLOAT
DrawArc
Set up the position and range with SetRange() and SetArc()
FLOAT Radius
Scale of the radius to draw at
SetAngles
Sets the min-max angles to draw on the dial
Used for setting the needle
Defaults are 135 and -45
INT Start
INT End
SetShow
Decides on the presentation of the dial
BOOL ShowNumbers
True to show numbers on the dial, else false
BOOL ShowMarks
Show marks
CalcScaleRange
Decide the range value for a 0->1 value
Returned value may be out of range
FLOAT ScaledRange
FLOAT
CalcAngRange
Decide the range value for an angle
FLOAT AngleDegrees
FLOAT
CalcScale
Decide the scale (0->1) to display at given a range value
FLOAT RangeVal
FLOAT
SetMarks
INT Marks
Number of marks on the dial
INT Subs
Number of marks before a 'main' mark - can be zero
ClearArea
Clears the draw area
This macro has no parameters
SetRange
Sets the min-max range to draw on the dial
INT Start
INT End
SetGaps
Sets the min-max of the span to draw on the X/Y marks
Defaults are 0 and 1
INT Start
INT End
SetJustify
BOOL RAlign
True for right/top/outer alignment
CalcAngle
Decide the angle to display at given a range value
FLOAT RangeVal
FLOAT
This component does not contain any properties
