Component: MIAC AllCode (MIAC: PC Peripheral)
Revision as of 10:31, 9 May 2018 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category MIAC: PC Peripheral
Image MIAC AllCode component
MIAC AllCode. dsPIC version of the MIAC loaded with the AllCode firmware. Usefull for SCADA, Control or Test applications. Allows you to control the MIAC using the programming language of choice. Compatible with simulation / Bluetooth / Wifi / RS232 and RS485
This component does not contain any downloadable macros
Simulation macro reference
CommsWrite
Writes a byte to the alt communications channel
BYTE Data
Range: 0-255
WriteTrans
Allows all transistor outputs to be switched on or off in a single command.
BYTE Value
Range: 0-15 or 0b0000 to 0b1111
LCDPixel
Controls a single pixel on the MIAC display
BYTE X
Range: 0-119
BYTE Y
Range: 0-49
BYTE State
Range: 0-1
CardCreate
Attempts to create a specific file on the card.
Returns 0 for success, 255 for no card or error.
<- STRING Filename
This parameter may be returned back to the caller
BYTE
CardDelete
Attempts to delete a specific file on the card.
<- STRING Filename
BYTE
LCDBitmap
Draws a bitmap file from the SD card onto the MIAC display
BYTE X
Range: 0-119
BYTE Y
Range: 0-49
<- STRING Filename
Range: 0-1
GetAPIVersion
Gets the API version of the Robot ARM Firmware
This macro has no parameters
BYTE
LCDNumber
Prints a number to the MIAC display starting from the current cursor position.
INT Value
Range: -32678 - 32767
CardInserted
Checks to see if a card is present.
Returns 0 for no card or 1 for card detected
BYTE
ReadRTC
Reads a value from the real time clock module.
Used for getting the time or date.
BYTE Unit
0=Second 1=Minute 2=Hour 3=Day 4=Month 5=Year
BYTE
CardOpen
Attempts to open a specific file from the card.
Returns 0 for file found and opened, 239 for file not found and 255 for no card.
<- STRING Filename
BYTE
CommsRead
Reads a byte from the alt communications channel
BYTE Timeout
Range: 0-255 : 0 = Don't wait / 1-255 = ms
BYTE
ReadKey
Reads a keypress from the keypad.
BYTE
WriteRTC
Writes a value to the real time clock module.
Used for setting the time or date.
BYTE Unit
BYTE Value
LCDBacklight
Controls the brightness of the LCD backlight.
BYTE Brightness
Range: 0-100
WriteRelay
Allows a single relay to be switched on or off.
BYTE Channel
Range 1-4
BYTE Value
0 = Off, 1 = On
LCDLine
Draws a single pixel width line on the MIAC display
BYTE X1
Range: 0-119
BYTE Y1
Range: 0-49
BYTE X2
Range: 0-119
BYTE Y2
Range: 0-49
LCDPrint
Prints a string to the MIAC display starting from the current cursor position.
<- STRING data
Range: 0-21
ReadInputs
Reads all digital inputs at once and returns as a binary value.
Input 1 = Bit 0
Input 8 = Bit 7
BYTE
CardReadByte
Reads a byte from the open file.
BYTE
WriteRelays
Allows all relays to be switched on or off in a single command.
BYTE Value
CardWriteByte
Appends a byte to the end of the open file.
Returns 0 for success.
BYTE data
BYTE
LCDRect
Draws a single pixel rectangle on the MIAC display
BYTE X1
Range: 0-119
BYTE Y1
Range: 0-49
BYTE X2
Range: 0-119
BYTE Y2
Range: 0-49
ReadAnalogInput
Reads a single digital input.
BYTE Channel
UINT
CommsBaud
Sets the Baud rate of the alt communications channel
BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
LCDOptions
Controls some of the LCD options
BYTE Foreground
Range: 0-1
BYTE Background
Range: 0-1
BYTE Transparent
Range: 0-1
LCDVerbose
Controls the Verbose mode.
When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
ReadDigitalInput
BYTE Channel
BYTE
PWMConfig
Sets the PWM configuration.
Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D
Period = 0 - 65535
Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
BYTE Channel
Range 0-1
UINT Period
Range: 0-65535
BYTE Scaler
Range: 0-3
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off.
Bit 0 = Enable AB
Bit 1 = A / Bit 2 = B
Bit 3 = C / Bit 4 = D
Bit 5 = Enable CD
BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
PWMDuty
Sets a single PWM channel duty.
Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD
Duty = 0 - 65535
BYTE Channel
Range 0-5
UINT Duty
LCDCursor
Sets the cursor position for the MIAC display
BYTE X
Range: 0-21
BYTE Y
Range: 0-4
WriteTran
Allows a single transistor output to be switched on or off.
BYTE Channel
Range 1-4
BYTE Value
0 = Off, 1 = On
LCDClear
Clears the MIAC display
Mode
This property is of type Fixed list of ints and can be referenced with the variable name SimMode.
Configures how the simulation component functions, does it simply simulate or does it control real hardware.
API Connection Type
This property is of type Fixed list of ints and can be referenced with the variable name APIType.
API connection mode.
COM - Bluetooth / RS232 / RS485
WIFI - Network
Network Interface
This property is of type Fixed list of ints and can be referenced with the variable name TCP_Base1::interface.
List of network interfaces connected to the PC.
Sets which interface we are communicating via.
My IP
This property is of type Line of text and can be referenced with the variable name MyIP.
My Local IP Address on the selected network interface
MIAC IP
This property is of type Line of text and can be referenced with the variable name IPAddress.
The IP address of the MIAC we want to connect to
