Component: GLCD Textfield (Displays: Graphical)
Author | Matrix TSL |
Version | 1.1 (Release) |
Category | Displays: Graphical |
GLCD Textfield component
A component to simplify the process of drawing text to a graphical display. Allows the graphical LCD to be used more like a standard alphanumeric display. Compatible with the Graphical LCDs.
Example program showing how to use the component with a graphical display.
GLCD TextField Example
Clear
Clears all text from the display
PrintString
Prints a string of ASCII characters to the display
- <- STRING Text
- Enter the text or variable to print to the display
PrintASCII
Prints a single ASCII character to the display
- BYTE character
- Holds an ASCII value
Prints a number to the display as an ASCII string
- INT Number
- Enter the number or variable to print to the display
ClearLine
Clears a single line of text from the display
- BYTE Line
- Line to clear. Range 0 to CharacterHeight - 1
Cursor
Moves the cursor on the LCD display
- BYTE x
- Sets the cursor position on the x plane, 0 is the left most cell
- BYTE y
- Sets the cursor position on the Y plane, 0 is the top most line
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
- ULONG Number
- BOOL Format
- 0 = Signed, 1 = Unsigned
SetDisplayOrientation
- BYTE Orientation
- 0=Default, 1=90°CW, 2=180°CW, 3=270°CW
GetCursorPosition
Gets the current position of the cursor
- BYTE Axis
- 0=X, 1=Y
Simulation macro reference
gLCD Object
This property is of type Panel object and can be referenced with the variable name glcd_obj.
Graphical LCD Object to draw the bitmap image to
Pixel Width
This property is of type Unsigned integer and can be referenced with the variable name PWidth.
Pixel width of selected display
Pixel Height
This property is of type Unsigned integer and can be referenced with the variable name PHeight.
Pixel height of selected display
Character Size
This property is of type Fixed list of ints and can be referenced with the variable name CharSize.
Configures the size of the displayed text and therefore the amount of text that can fit on the display.
Character Width 0/2
This property is of type Unsigned integer and can be referenced with the variable name CWidth.
Number of horizontal characters that can fit onto the display.
Assuming display orientation 0 or 2.
Character Width 1/3
This property is of type Unsigned integer and can be referenced with the variable name CWidth2.
Assuming display orientation 1 or 3.
Character Height 0/2
This property is of type Unsigned integer and can be referenced with the variable name CHeight.
Number of vertical characters that can fit onto the display.
Character Height 1/3
This property is of type Unsigned integer and can be referenced with the variable name CHeight2.
ColourDisplay
This property is of type True or false and can be referenced with the variable name Colour_Display.
Automatically detects if the graphical LCD object is colour or monochrome
