Component: Touch Screen (XPT2046) (Displays: Graphical)
Revision as of 10:31, 9 May 2018 by BenR (talk | contribs) (XML import)
Version 2.0 (Release)
Category Displays: Graphical
Image Touch Screen (XPT2046) component
Low level routines for controlling or interacting with the XPT2046 touch screen controller IC found on a lot of common low cost resistive touch screen products.
Example using the XPT2046 touchscreen driver IC with a 4.3" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 4.3 Touch Example using the XPT2046 touchscreen driver IC with a 7" TFT Display using the SSD1963 Graphical LCD Controller. FC6 Icon.png GLCD 7 Touch
SampleSensor
Reads the touch controller and returns true if there is currently a touch in progress.
The touch coordinates can be read using the ReadCoord macro.
Return 0 = No Touch, 1 = Touch in progress
This macro has no parameters
BYTE
ReadCoord
Reads a coordinate returned from the Sample Sensor macro.
Coordinate is scaled to the X/Y Pixel bounds specified.
BYTE Coordinate
0 = X, 1 = Y, 2 = Pressure
UINT
Activates the SPI peripheral and claims control over the I/O pins.
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Analogue Mode
This property is of type Fixed list of ints and can be referenced with the variable name AnMode.
X Pixel
This property is of type Unsigned integer and can be referenced with the variable name Xpix.
Y Pixel
This property is of type Unsigned integer and can be referenced with the variable name Ypix.
Flip X
This property is of type True or false and can be referenced with the variable name FlipX.
Flip Y
This property is of type True or false and can be referenced with the variable name FlipY.
Label used to identify the component on the panel.
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
