Component: DALI Slave (Comms: System)
Revision as of 14:50, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Author MatrixTSL
Version 1.0 (Release)
Category Comms: System
Image DALI Slave component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND using external circuitry.
DALI Master Example, reads the value of a keypad and sends out DALI commands based on the key pressed, 1 = switch on a slave's light, 2 = switch off a slave's light, 3 = read the slave's light level. FC6 Icon.png DALI Master Example1 DALI Slave Example, listens for DALI messages and checks that the group is correct before attempting to process the request and if required reply to the master. FC6 Icon.png DALI Slave Example1
ReceiveForwardFrame
Attempts to receive an 16-bit command from the master controller.
0xFFFF indicates timeout or no reply
This macro has no parameters
UINT
CheckForIndividualAddress
Tests the 16-bit incoming data for the defined individual address
Returns 0 for no match, returns 1 for a match
UINT Data
BYTE
CollectDataByte
Returns the data byte from a 16-bit data packet
UINT Data
BYTE
CheckForGroupAddress
Tests the 16-bit incoming data for the defined group address
UINT Data
BYTE
CollectPacketType
Returns if the incoming packet was data or a command.
Return of 0 = Data
Return of 1 = Command
UINT Data
BYTE
TransmitBackwardFrame
Send out a 8-bit frame consisting of a data byte.
BYTE Data
Data Byte
BYTE
Configures the UART serial interface.
Simulation macro reference
TX Pin
This property is of type Single digital pin and can be referenced with the variable name TXPIN.
RX Pin
This property is of type Single digital pin and can be referenced with the variable name RXPIN.
Individual Address
This property is of type Unsigned integer and can be referenced with the variable name IndAddress.
Address ranging from 0-63
Group Address
This property is of type Unsigned integer and can be referenced with the variable name GrAddress.
Address ranging from 0-15
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
