Component: Temp Humidity DHT22 (101020019) (Grove)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.2 (Release)
Category Grove
Image Temp Humidity DHT22 (101020019) component
The DHT22 temperature and humidity sensor is a popular sensor allowing the ambient temperature and relative humidty to be monitored digitally. Humidity Range = 0% - 100% +/- 2% Temperature Range = -40 - 80 Degrees C +/- 0.5 Degrees C
GetTempWhole
Gets the whole number portion of the temperature returned by calling SampleSensor.
If temperature is 15.8 degrees C then this function would return 15.
This macro has no parameters
INT
GetHumidityFloat
Gets the humidity returned by calling SampleSensor as a floating point number.
If humidity is 15.8 % then this function would return 15.8.
FLOAT
GetHumidityString
Gets the humidity returned by calling SampleSensor as a string.
If humidity is 15.8 % then this function would return "15.8".
STRING
GetTempString
Gets the temperature returned by calling SampleSensor as a string.
If temperature is 15.8 degrees C then this function would return "15.8".
STRING
GetHumidityWhole
Gets the whole number portion of the humidity returned by calling SampleSensor.
INT
GetTempReal
Gets the real number portion of the temperature returned by calling SampleSensor.
If temperature is 15.8 degrees C then this function would return 8.
INT
GetHumidityReal
Gets the real number portion of the humidity returned by calling SampleSensor.
If humidity is 15.8 % then this function would return 8.
INT
SampleSensor
Communicates with the DHT11 sensor and receives the temperature and humidity
readings.
Returns 0 for success, 1 for no communication detected and 2 for checksum error.
BYTE
GetTempFloat
Gets the temperature returned by calling SampleSensor as a floating point number.
If temperature is 15.8 degrees C then this function would return 15.8.
FLOAT
Simulation macro reference
SIG Pin
This property is of type Single digital pin and can be referenced with the variable name dpin.
Microcontroller I/O Pin connected to the DHT11 sensor data pin.
Use Checksum
This property is of type True or false and can be referenced with the variable name csum.
The checksum value is used to ensure the data being received is correct.
Yes = Only receive data if checksum is correct
No = Ignore checksum
