Component: LED Bar v2.0 (104020006) (Grove)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.0 (Release)
Category Grove
Image LED Bar v2.0 (104020006) component
LED Bar is comprised of a 10 segment LED gauge bar and an MY9221 LED controlling chip. It can be used as a indicator for remaining battery life, voltage, water level, music volume or other values that require a gradient display. There are 10 LED bars in the LED bar graph: one red, one yellow, one light green, and the rest green. It lights up the LEDs sequentially from red to green, so the entire bar graph is lit up in the end.
SetBinary
Allows a binary value to be shown on the LEDs.
Red = Bit0
Yellow = Bit1
Light Green = Bit2
Green = Bit3 - Bit9
UINT Data
SetLevelReverse
Set level 0-10 in reverse, green to red, where 10 is red
Level 0 means all leds off while level 5 means leds 1-5 on and 6-10 will be off
BYTE Level
Range: 0-10
SetLevel
Set level 0-10, red to green, where 1 is red
BYTE Level
Range: 0-10
SetSingleLED
Allows a single LED to be controlled and switched on or off.
LED 0 = Red
LED 1 = Yellow
LED 2 = Light Green
LED 3-9 = Green
BYTE LED
Range: 0-9
BYTE State
0=Off / 1=On
Simulation macro reference
LatchDataSim
Latches the data and shifts the new input to the output.
This macro has no parameters
Data
This property is of type Single digital pin and can be referenced with the variable name Data.
Data pin
Clock
This property is of type Single digital pin and can be referenced with the variable name Clock.
Clock pin
