Component: Accel Mag 6 Axis (LSM303DLHC) (Sensors)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 2.0 (Release)
Category Sensors
Image Accel Mag 6_Axis (LSM303DLHC) component
LSM303DLHC Combined 6-Axis Accelerometer and Magnetometer sensors Useful for working out data such as Pitch and Yaw.
SimReset1G
This macro has no parameters
UpdateCompassData
Reads from the compass and updates the local XYZ variables.
Returns 1 for new data and 0 for no new data
BYTE
SimSetAccelerometer
Allows the XYZ slider values to be set via the simulation
INT X
INT Y
INT Z
CollectXYZData
Collect the data from the local accelerometer buffers.
The Axis parameter specifies the Axis to be read.
0 / 'x' / 'X' - X axis
1 / 'y' / 'Y' - Y axis
2 / 'z' / 'Z' - Z axis
BYTE Axis
INT
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables.
BYTE
SimSetCompass
INT X
INT Y
INT Z
Sets up up the communication bus and initialises the accelerometer module.
Returns 0 for success and > 0 for fail.
BYTE
Simulation macro reference
Power Mode
This property is of type Fixed list of ints and can be referenced with the variable name power_mode.
Accel Data Rate
This property is of type Fixed list of ints and can be referenced with the variable name accel_data_rate.
Accel Scale
This property is of type Fixed list of ints and can be referenced with the variable name accel_scale.
Compass Data Rate
This property is of type Fixed list of ints and can be referenced with the variable name compass_data_rate.
Compass Scale
This property is of type Fixed list of ints and can be referenced with the variable name compass_scale.
Comms Mode
This property is of type Fixed list of ints and can be referenced with the variable name CommsMode.
Specifies the communications mode.
Interrupt - Wait for the interrupt pin to go high before allowing new data to be sampled.
Polling - New data is sampled without needing to check the interrupt pin.
Bit Depth
This property is of type Signed integer and can be referenced with the variable name bit_depth.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::CHANNEL.
Channel selection
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c::BAUD.
Baud rate to be used
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c::SCL.
Interrupt Pin
This property is of type Single digital pin and can be referenced with the variable name int_pin.
Sim Type
This property is of type Fixed list of ints and can be referenced with the variable name SimType.
Controls how the simulation data is generated, via the component GUI or via a I2C injector.
This property is of type True or false and can be referenced with the variable name cal_i2c::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_i2c::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::Injector.
