Component: IO Expander (MCP23017) (Comms: System)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.0 (Release)
Category Comms: System
Image IO Expander (MCP23017) component
Provides 16 digital input/output pins arranged into two 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins.
ReadPort
Reads a value to one of the ports with a mask.
Configures the masked bits to be inputs before reading the input value.
BYTE Port
0=PortA, 1=PortB
BYTE Mask
Allows port bits to be modified without effecting other bits, 255 = write full port.
BYTE
ConfigureInversion
Configures the pin inversion for the two ports.
Disabled on all pins by default.
BYTE PortA
Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
BYTE PortB
Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPortPin
Reads a single port pin from one of the ports.
Configures the pins to be an input before reading the input value.
Returns 0 or 1 corresponding to the value on the port pin.
BYTE Port
0=PortA, 1=PortB
BYTE Pin
Port pin to read. Range: 0-7
BYTE
WritePortPin
Writes a single port pin on one of the ports.
Configures the pins to be an output before writing the input value.
BYTE Port
0=PortA, 1=PortB
BYTE Pin
BYTE Value
Value to output on the selected pin. Range: 0-1
WritePort
Writes a value to one of the ports with a mask.
Configures the masked bits to be outputs before writing the output value.
BYTE Port
0=PortA, 1=PortB
BYTE Mask
BYTE Value
Value to write. Range 0-255
ConfigurePullups
Configures the pullups for the two ports.
BYTE PortA
Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
BYTE PortB
Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadRegister
Reads an 8-bit value from a register on the I/O expander device.
BYTE Address
Register address to write to. Range: 0-15
BYTE
WriteRegister
Writes an 8-bit value to a register on the I/O expander device.
BYTE Address
BYTE Value
Value to write. Range: 0-255
This macro has no parameters
Simulation macro reference
External Address
This property is of type Fixed list of ints and can be referenced with the variable name ExtAddress.
Selects the value of the three address pins for the MCP23S17.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c1::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c1::BAUD.
Baud rate to be used
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
Reset Pin
This property is of type Single digital pin and can be referenced with the variable name reset_pin.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::Injector.
