Component: Thermistor (Sensors)
Revision as of 15:08, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Version 1.1 (Release)
Category Sensors
Image Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. Default calibration is for the EBM003 module.
GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
This macro has no parameters
INT
GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
FLOAT
CalculateTemperature
Converts the input ADC value and returns the Temperature in tenths of degree C
UINT ADCValue
ADC Reading to be converted
INT
GetADCValue
Returns the Raw ADC value from the Analogue Channel
UINT
Simulation macro reference
SetChannel
Set the ADC Channel
INT ChannelID
SetMinMax
Set the minimum and maximum temperature values that can be shown and set on the thermometer readout.
FLOAT Min
Minimum Value
FLOAT Max
Maximum Value
SetTemperature
Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
FLOAT Temperature
Zero to one value - representing min-max of the sensor.
ADC Channel
This property is of type Single analog pin and can be referenced with the variable name CHANNEL.
The ADC channel to which the thermistor circuit is connected.
It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected
between the ADC pin and +V.
Wiring
This property is of type Fixed list of ints and can be referenced with the variable name Thermistor_base1::Wiring.
Specifies the arrangement of the Thermistor and Fixed Resistor.
Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC.
Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
ADC Bit Resolution
This property is of type Unsigned integer and can be referenced with the variable name ADC_BITS.
Resistor Value
This property is of type Unsigned integer and can be referenced with the variable name RESISTOR.
Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the
positive supply rail.
-25C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name M25.
Value in Ohms of the Thermistor at -25 deg C
0C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P0.
Value in Ohms of the Thermistor at 0 deg C
This property is of type Unsigned integer and can be referenced with the variable name P25.
Value in Ohms of the Thermistor at 25 deg C
50C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P50.
Value in Ohms of the Thermistor at 50 deg C
75C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P75.
Value in Ohms of the Thermistor at 75 deg C
100C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P100.
Value in Ohms of the Thermistor at 100 deg C
125C Thermistor Value
This property is of type Unsigned integer and can be referenced with the variable name P125.
Value in Ohms of the Thermistor at 125 deg C
A text label to help you identify the component on the panel.
Min. Temp.
This property is of type Floating point and can be referenced with the variable name min_temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Max. Temp.
This property is of type Floating point and can be referenced with the variable name max_temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Scale divisions
This property is of type Unsigned integer and can be referenced with the variable name scale_divisions.
Number of numbered divisions shown on the thermometer scale.
