Component: Temp Humidity (HTS221) (Sensors)
Revision as of 11:59, 31 May 2018 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Sensors
Image Temp Humidity (HTS221) component
A temperature and relative humidity sensor allowing the ambient temperature and relative humidity to be monitored digitally. Humidity Range = 0% - 100% +/- 3.5% Temperature Range = -40 - 120 Degrees C +/- 0.5 Degrees C
ReadHumidityInt
Samples the humidity from the sensor and returns the relative humidity reading as a integer byte from 0 to 100
This macro has no parameters
BYTE
DataAvailable
Checks to see if new sensor data is available.
Returns 0 if no new data is available.
Returns 1 if new Temperature data is available.
Returns 2 if new Humidity data is available.
Returns 3 if new Temp and Humidity data is available.
BYTE
ControlHeater
Controls the in-built heater element to speed up sensor recovery time in case of condensation. Humidity and temperature cannot be read while Heater is active.
BOOL Active
0 = Off (Sensor Reading Available) / 1 = On (Sensor Reading Disabled)
ReadTemperatureInt
Samples the temperature from the sensor and returns the reading in degrees C as an integer from -40 to 120.
INT
ReadHumidityReal
Samples the humidity from the sensor and returns the relative humidity reading as a float from 0.0 to 100.0.
FLOAT
ReadRegister
Reads an 8-bit value from one of the registers onboard the sensor IC.
BYTE Address
BYTE
ReadTemperatureReal
Samples the temperature from the sensor and returns the reading in degrees C as a float from -40.0 to 120.0.
FLOAT
WriteRegister
Writes a value to a register on the sensor IC.
BYTE Address
BYTE Value
Configures the I2C peripheral ready for communications.
Simulation macro reference
Data Rate
This property is of type Fixed list of ints and can be referenced with the variable name DataRate.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c1::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c1::BAUD.
Baud rate to be used
Sim Type
This property is of type Fixed list of ints and can be referenced with the variable name SimType.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ScopeTraces.
Selects if the component pin connections are automatically generated on the data recorder window or not.
Yes: Automatically add the component pins to a group on the data recorder which will reflect the sim data during simultion.
No: Do not show the pin signals on the data recorder window.
This property is of type True or false and can be referenced with the variable name cal_i2c1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::Injector.
