Component: SPI (CAL) (Peripheral CAL)
Revision as of 11:27, 23 July 2018 by BenR (talk | contribs)
Version 2.0 (Release)
Category Peripheral CAL
Image SPI (CAL) component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Serial Peripheral Interface peripheral.
Master_Enable_CS
Outputs a low signal to the chip select pin to select the remote slave device.
This macro has no parameters
Slave_Uninit
Uninitialise the Slave
Master_Transaction
Sends and receives data bytes via the SPI channel.
The Buffer is to contain the data to be sent, and is overwritten by the retuning data from the device.
Returns 1 for success, 0 for failure
BYTE Buffer
UINT Length
Number of bytes to transfer
BYTE
Slave_Init
Initialise the Slave
Master_Disable_CS
Outputs a high signal to the chip select pin to deselect the remote slave device.
Master_Uninit
Uninitialise the Master
Master_Byte
Sends and receives a data byte
BYTE DataOut
BYTE
Slave_TxByte
Sets the data to be transmitted to the SPI master.
BYTE Data
Slave_RxByte
Returns the data received from the SPI Master
BYTE
SetPrescaler
Sets the prescaler value for the clock divider chain
BYTE Prescaler
Master_Init
Initialise the Master
Simulation macro reference
Prv_TextConsole
Send text to the SPI console.
Exposed as part of the CAL_SPI component to allow none AutoCS pins and other.
<- STRING str
This parameter may be returned back to the caller
BYTE Colour
0=Default, 1=TX, 2=RX
BYTE AppendTimestamp
0=Don't Append / 1=Do Append
ChangeMode
GetValue
Reads Named property Value.
<- STRING Name
STRING
GetConsoleHandle
Returns a handle to the console used by this component
HANDLE
SetValue
Change Named property to new Value.
<- STRING Name
<- STRING Value
GetList
returns Named property list
<- STRING Name
STRING
Component Enable
This property is of type True or false and can be referenced with the variable name ENABLED.
A global flag to enable or disable the SPI component from producing code.
Useful for generating components with multiple communications options.
This property is of type Fixed list of ints and can be referenced with the variable name CHANNEL.
SPI Channel selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name CLK.
Use Auto CS
This property is of type True or false and can be referenced with the variable name UseAutoCS.
Allow the SPI component to manage the CS pin for us in Master mode.
On initialise the CS pin is automatically set high to disable the remote SPI device.
Set to No if you want to create a component with multiple CS pins or if you want to manage the CS pin yourself.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Mode
This property is of type Fixed list of ints and can be referenced with the variable name Mode.
Configures the mode of the SPI component.
Currently only Master mode is supported.
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name PR_SCALE.
Prescale option selector
Clock Phase
This property is of type Fixed list of ints and can be referenced with the variable name CKE.
Clock Polarity
This property is of type Fixed list of ints and can be referenced with the variable name CKP.
Sample Point
This property is of type Fixed list of ints and can be referenced with the variable name SMP.
Data bit read sample point
This property is of type True or false and can be referenced with the variable name ScopeTraces.
This property is of type True or false and can be referenced with the variable name ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
