Component: Fan Pump (Industrial)
Revision as of 16:23, 27 November 2018 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Industrial
Image Fan Pump component
A simple rotating fan or pump. The component has macros to set and get the current rotational speed. Compatible with SCADA interconnecting pipe components.
This component does not contain any downloadable macros
Simulation macro reference
GetSpeed
Gets the current speed of the fan in RPM.
This macro has no parameters
FLOAT
SetSpeed
Sets the speed of the fan in RPM.
FLOAT Speed
Speed in RPM
Show Title
This property is of type True or false and can be referenced with the variable name ShowTitle.
Decides if the fan title is shown
Title Colour
This property is of type Color picker and can be referenced with the variable name TitleColour.
Title Label Color
Title Text
This property is of type Line of text and can be referenced with the variable name TitleText.
Title Label Text
Title Scale
This property is of type Floating point and can be referenced with the variable name TitleScale.
Controls the size of the title text on the panel, default 1.2
Show Label
This property is of type True or false and can be referenced with the variable name ShowLabel.
Decides if a label is shown detailing current amount of produce in the hopper
Label Colour
This property is of type Color picker and can be referenced with the variable name LabelColour.
Sets the label colour
Label Units
This property is of type Line of text and can be referenced with the variable name LabelUnits.
Adds a unit to the end of the label
Label Decimal Points
This property is of type Unsigned integer and can be referenced with the variable name LabelDecPoints.
Number of decimal points to round the label value to.
Label Scale
This property is of type Floating point and can be referenced with the variable name LabelScale.
Sets the size of the label on the panel, default 1.0
Propeller Colour
This property is of type Color picker and can be referenced with the variable name PropColour.
Sets the colour of the propeller.
Background Colour
This property is of type Color picker and can be referenced with the variable name BgColour.
