Component: Bitmap Drawer ROM (Displays: Graphical)
Revision as of 10:46, 28 November 2018 by BenR (talk | contribs)
Version 2.0 (Release)
Category Displays: Graphical
Image Bitmap Drawer ROM component
A component to simplify the process of drawing bitmap images to a graphical display. Stores up to 10 bitmap images inside ROM based look up tables. Compatible with 24-bit / 256 Colour / 16 Colour / Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to.
Here is an example which loops drawing a monochrome and 24-bit bitmaps to the EBM001 graphical display.
FC6 Icon.png Bitmap Drawer Demo
The bitmap files used in the example can be found here.
ZIP Icon.png Bitmap Drawer Files
Here is another example which overlays several monochrome images to give the impression of animation. Shows a pair of eyes, which can randomly and momentarily look left, right or blink. FC6 Icon.png Bitmap Drawer Demo 2 The bitmap files used in the example can be found here.
File:BitmapDrawerDemo2.zip
GetHeight
Returns the height of the loaded bitmap file in pixels.
BYTE BitmapIndex
Selects from attached bitmaps. Range: 0-9
UINT
GetWidth
Returns the width of the loaded bitmap file in pixels.
BYTE BitmapIndex
UINT
SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
BYTE R
BYTE G
BYTE B
Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y.
BYTE BitmapIndex
UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
BYTE Orientation
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Simulation macro reference
gLCD Object
This property is of type Panel object and can be referenced with the variable name glcd_obj.
Graphical LCD Object to draw the bitmap image to
ColourDisplay
This property is of type True or false and can be referenced with the variable name Colour_Display.
Automatically detects if the graphical LCD object is colour or monochrome
ROM Bytes
This property is of type Unsigned integer and can be referenced with the variable name ROMusage.
Total number of ROM bytes used to store attached bitmap images.
Number of Bitmaps
This property is of type Fixed list of ints and can be referenced with the variable name NumBitmaps.
Number of bitmaps the component can store and draw to the LCD.
Min 1 / Max 10
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file0.
Bitmap file you wish to embed into the program.
Compatible with .bmp files in the following formats: 24-Bit / 256 Colour / 16 Colour / Monochrome
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth0.
Number of bits per pixel.
Currently the component only supports bitmap files with 1-bit or 24-bit colour depth.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len0.
The number of bytes of ROM the bitmap file will consume.
You can vie wthe number of ROM bytes available on your target device using the Device Helper component.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth0.
Width of the bitmap file in pixels
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight0.
Height of the bitmap file in pixels
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset0.
Offset in the file where the bitmap pixel data starts
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file1.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth1.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len1.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth1.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight1.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset1.
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file2.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth2.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len2.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth2.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight2.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset2.
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file3.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth3.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len3.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth3.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight3.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset3.
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file4.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth4.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len4.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth4.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight4.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset4.
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file5.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth5.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len5.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth5.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight5.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset5.
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file6.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth6.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len6.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth6.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight6.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset6.
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file7.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth7.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len7.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth7.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight7.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset7.
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file8.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth8.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len8.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth8.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight8.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset8.
Bitmap File
This property is of type Filename and can be referenced with the variable name bitmap_file9.
File Colour Depth
This property is of type Unsigned integer and can be referenced with the variable name ColourDepth9.
File Length
This property is of type Unsigned integer and can be referenced with the variable name file_Len9.
File Width
This property is of type Unsigned integer and can be referenced with the variable name FileWidth9.
File Height
This property is of type Unsigned integer and can be referenced with the variable name FileHeight9.
Data Offset
This property is of type Unsigned integer and can be referenced with the variable name DataOffset9.
