Component: Injector (SCADA Slave UART) (Comms)
Revision as of 11:09, 18 December 2018 by BenR (talk | contribs) (XML import)
Version 1.2 (Release)
Category Comms
This inherits from Data Injector Template
Image Injector (SCADA Slave UART) component
Comms data injector to allow a Serial UART peripheral to be attached to a comms component. The component will forward any byte transactions through to a SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly drive a physical UART.
This component does not contain any downloadable macros
Simulation macro reference
This component inherits simulation macros from Data Injector Template
InitialiseInjector
<- STRING InjectorName
This parameter may be returned back to the caller
BYTE
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
This call is provided by Data Injector Template
This macro has no parameters
UINT
TxByte
BYTE DataByte
RxByte
Attempt to receive a byte back from the injector
0 - 255 = Valid data
256 = RX timeout no data available
UINT
GetTxConsoleHandle
HANDLE
ChangeState
Sets the state of the bus.
SPI - Controls the chip select pin
I2C - Controls the start/restart/stop status
BYTE State
SPI: 0=CSLow, 1=CSHigh I2C: 0=Stop, 1=Start, 2=Restart
GetRxConsoleHandle
HANDLE
GetConsoleHandle
HANDLE
SCADA Slave
This property is of type Panel object and can be referenced with the variable name SCADASlave.
BAUD Rate
This property is of type Fixed list of ints and can be referenced with the variable name Baud.
Sets the data bit rate of the Serial UART.
See the SCADA Slave UART Baud macro for valid values,
RS485 Direction Control
This property is of type True or false and can be referenced with the variable name RS485DirCon.
Allows an I/O pin to be automatically assigned when transmitting and receiving.
RS485 Pin Number
This property is of type Unsigned integer and can be referenced with the variable name RS485PIN.
Digital I/O pin number to use for the RS485 data direction pin
TX Pin State
This property is of type Fixed list of ints and can be referenced with the variable name TXPinState.
Decides the state of the RS485 data direction pin when transmitting data.
RX Pin State
This property is of type Fixed list of ints and can be referenced with the variable name RXPinState.
Decides the state of the RS485 data direction pin when receiving data.
