Component: GLCD Graph Creator XY (Graphical Library)
Revision as of 10:23, 12 March 2019 by BenR (talk | contribs) (→‎Examples)
Version 1.2 (Release)
Category Graphical Library
Image GLCD Graph Creator XY component
A component to simplify the process of drawing XY graphs and charts using a graphical LCD.
The graph creator XY component must be linked to the graphical LCD using the gLCD Object property.
The X Coord, Y Coord, Width and Height component properties set the size and position of the graph on the gLCD.
In the attached example the ADC component sets the input to the graph. Every 50ms a sample is taken and added to the graph.
FC6 Icon.png Graph Creator Demo
Any size of graph can be created. For efficiency it is best to try and stick to the following rules.
  • The width should be equal to or a multiple of the X input range - Min Value 0 to Max Value 255 = input range of 256
  • The height should be equal to or a multiple of the Y input range - Min Value 0 to Max Value 255 = input range of 256
  • If Show Border is enabled then Width and Height should be as above plus 2 to account for the border pixels
AddPoint
Adds a new data point to the graph.
INT X
X Data Value to plot
INT Y
Y Data Value to plot
BYTE Index
Plot Index: Range 0-7
Initialises the graph object on the GLCD to the specified dimensions.
This macro has no parameters
Simulation macro reference
ExportToCSV
Exports the data in the graph to a CSV file.
<- STRING Filename
This parameter may be returned back to the caller
gLCD Object
This property is of type Panel object and can be referenced with the variable name glcd_obj.
Graphical LCD Object to draw the graph on
ColourDisplay
This property is of type True or false and can be referenced with the variable name Colour_Display.
Automatically detects if the graphical LCD object is colour or monochrome
X Coord
This property is of type Unsigned integer and can be referenced with the variable name XC.
X coordinate for the top left of the graph container rectangle
Y Coord
This property is of type Unsigned integer and can be referenced with the variable name YC.
Y coordinate for the top left of the graph container rectangle
Width
This property is of type Unsigned integer and can be referenced with the variable name WP.
Horizontal size of the graph in pixels
Height
This property is of type Unsigned integer and can be referenced with the variable name HP.
Vertical size of the graph in pixels
Number Of Plots
This property is of type Fixed list of ints and can be referenced with the variable name NumPlots.
Determines the number of plots that can be displayed simultaneously on the graph.
Monochrome displays can only support a single plot.
Number Of Points
This property is of type Unsigned integer and can be referenced with the variable name NumPoints.
Number of data points the graph can store, multiplied by the number of plots.
Graph Style
This property is of type Fixed list of ints and can be referenced with the variable name GraphStyle.
Controls the graph draw style.
Point - Draws a single point
Line - Draws a line from the last point to the new point
Min X Value
This property is of type Signed integer and can be referenced with the variable name MinXVal.
Value to represent the bottom Y axis on the graph
Max X Value
This property is of type Signed integer and can be referenced with the variable name MaxXVal.
Value to represent the top Y axis on the graph
Min Y Value
This property is of type Signed integer and can be referenced with the variable name MinYVal.
Max Y Value
This property is of type Signed integer and can be referenced with the variable name MaxYVal.
Show Border
This property is of type True or false and can be referenced with the variable name ShowBorder.
Decides if a border for the graph is generated
Show Grid
This property is of type Fixed list of ints and can be referenced with the variable name ShowGrid.
Decides if a X or Y grid is shown for the graph
Background Colour
This property is of type Color picker and can be referenced with the variable name BgCol.
Determines the graph background colour.
Plot 0 Colour
This property is of type Color picker and can be referenced with the variable name P1Col.
Determines the graph plot colour.
