Component: Bitmap Drawer FAT (Displays: Graphical)
Revision as of 10:44, 12 March 2019 by BenR (talk | contribs) (→‎Examples)
Version 2.0 (Release)
Category Displays: Graphical
Image Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to.
The Bitmap Drawer FAT component must be linked to the graphical LCD using the gLCD Object property and to the FAT component using the FAT Object property.
Here is an example which loops drawing a monochrome and 24-bit bitmaps to the EBM001 graphical display.
FC6 Icon.png Bitmap Drawer FAT Demo
The bitmap files used in the example can be found here.
ZIP Icon.png Bitmap Drawer FAT Files
GetHeight
Returns the height of the loaded bitmap file in pixels.
<- STRING Filename
The filename of the bitmap we want to measure
This parameter may be returned back to the caller
UINT
GetWidth
Returns the width of the loaded bitmap file in pixels.
<- STRING Filename
UINT
SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
BYTE R
BYTE G
BYTE B
Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y.
Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
<- STRING Filename
Bitmap file to open from current directory on SD card 8.3 format
UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
BYTE Orientation
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
BYTE
Simulation macro reference
FAT Object
This property is of type Panel object and can be referenced with the variable name fat_obj.
FAT / SD Card Object to read the bitmap image from
gLCD Object
This property is of type Panel object and can be referenced with the variable name glcd_obj.
Graphical LCD Object to draw the bitmap image to
ColourDisplay
This property is of type True or false and can be referenced with the variable name Colour_Display.
Automatically detects if the graphical LCD object is colour or monochrome
