Component: SCADA (Interface Board) (SCADA Slaves)
Revision as of 13:17, 12 March 2019 by BenR (talk | contribs) (→‎Examples)
Version 1.0 (Release)
Category SCADA Slaves
Image SCADA (Interface Board) component
Connects to a Embeddded Interface Board running the SCADA Firmware allowing the board to become a slave to the flowcode simulation runtime. Supports: Digital IO / ADC / I2C / SPI / PWM / UART / DAC / Servo See Instructables for open source project files.
Direct Slave Access
Here is a simple demo to switch on and off digital pin 5.
FC6 Icon.png Simple Interface Board Demo
Rapid Development - Virtualised SPI
A feature of the SCADA Slave interface is to use the component for rapid development.
The SCADA Slave hardware can be used to take communications from the Flowcode simulation and transfer them to a real world device allowing for easy code generation and test without having to download to a target microcontroller device.
The CS pin and SPI Prescaler are set via the properties of the Injector component.
The SPI Master component is linked to the Injector component via the Injector property.
The Injector component is linked to the SCADA Slave component via the SCADA Slave property.
FC6 Icon.png Interface Board SCADA Slave SPI Demo
Rapid Development - Virtualised I2C
The I2C Master component is linked to the Injector component via the Injector property.
FC6 Icon.png Interface Board SCADA Slave I2C Demo
Rapid Development - Virtualised UART
The Baud rate and optional RS485 Properties are set via the properties of the Injector component.
The UART component is linked to the Injector component via the Injector property.
FC6 Icon.png Interface Board SCADA Slave UART Demo
This component does not contain any downloadable macros
Simulation macro reference
I2CInitialise
This macro has no parameters
IOGetInputPin
BYTE Pin
Range: 0-17
BOOL : Returns true if the operation is a success, else false
UARTBaud
Change the Baud rate of the UART
BYTE Rate
ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
BYTE ADCChannel
Range: 0-5
BYTE
UARTInitialise
Initialsie the UART module ready for communications
UARTTX
Transmit a byte via the UART
BYTE Data
I2CRestart
WIFIIsConnected
Checks to see if the WIFI is active and connected
PWMDisable
Disable a PWM output
BYTE Channel
Range: 0-1
I2CReceive
BOOL Last
BYTE
I2CStart
SPITransfer
BYTE DataOut
BYTE
I2CStop
WIFISetSSID
Assign the SSID and password for the network you wish to connect the board to.
Stores the parameters into ROM for later USB free setup.
<- STRING SSID
Name of the network you wish to connect to
This parameter may be returned back to the caller
<- STRING Password
ServoDisable
Disable a Servo output
BYTE Channel
Range: 0-5
SPIPrescaler
BYTE Prescaler
Range: 0-2
ServoEnable
Enable a Servo output
BYTE Channel
Range: 0-5
UARTRXCount
Checks to see how many bytes have been received by the UART
BYTE
ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
BYTE ADCChannel
Range: 0-5
UINT
IOSetOutputPin
BYTE Pin
Range: 0-17
BOOL State
Range: 0-1
ServoSetPosition8
Sets the position as an 8-bit value
BYTE Channel
Range: 0-1
BYTE Position
Range: 0-255
SPIInitialise
WIFIGetIP
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI,
Use the WIFIIsConnected first to check the WIFI is active.
STRING
I2CSend
BYTE DataOut
PWMSetPrescaler
BYTE Prescaler
PWMSetDuty8
BYTE Channel
Range: 0-1
BYTE Duty
Range: 0-255
PWMEnable
Enable a PWM output
BYTE Channel
Range: 0-1
UARTRX
Receive a byte from the RX buffer.
Recommend callinng UARTRXCount first to check fo available data.
BYTE
Connection Type
This property is of type Fixed list of ints and can be referenced with the variable name ConnType.
Refresh Ports
This property is of type True or false and can be referenced with the variable name scada_uart1::RefreshPorts.
COM Port
This property is of type Fixed list of ints and can be referenced with the variable name scada_uart1::com_port.
Lists all the current available COM port hardware on your PC.
Network Interface
This property is of type Fixed list of ints and can be referenced with the variable name NetworkComms1::NetworkInterface.
Some computers may have several network interfaces such as ethernet ports and wifi access.
Select the correct network interface for the network you wish to connect to.
Use the IP address to confirm you are connected to the right network.
IP Address
This property is of type Line of text and can be referenced with the variable name NetworkComms1::IPAddress.
IP Address of the selected network interface.
WIFI IP
This property is of type Line of text and can be referenced with the variable name WIFIIP.
IP Address of the device we want to control
Console Log
This property is of type True or false and can be referenced with the variable name ConsoleLog.
Create an automatic console log of the commands sent to the device
Log Mode
This property is of type Fixed list of ints and can be referenced with the variable name LogMode.
Controls how the console data is formatted.
Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality
Command Log gives a more in depth analysis of the outgoing commands and incoming returns
Show Raw
This property is of type True or false and can be referenced with the variable name ShowRaw.
Shows the raw data stream via a console window
