Component: Digital Potentiometer (MCP41XX MCP42XX) (Analog Output)
Revision as of 12:46, 29 May 2019 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Analog Output
Image Digital Potentiometer (MCP41XX MCP42XX) component
The MCP41XX and MCP42XX device range supports up to 2 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
IncrementWiper
Increments a single volatile wiper value
BYTE Index
Range: 0-3
DecrementWiper
Decrements a single volatile wiper value
BYTE Index
Range: 0-1
SetWiper
Sets the value of a single wiper
BYTE Index
Range: 0-3
UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
BOOL MemoryType
0=Volatile, 1=Nonvolatile
ReadAddress
Reads a value from one of the registers on the device
BYTE Address
Range: 0-15
UINT
WriteAddress
Writes a value to one of the registers on the device
BYTE Address
Range: 0-15
UINT Value
Range: 0-256
Startup the SPI peripheral ready for communications.
This macro has no parameters
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MOSI Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::MOSIPins.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
MISO Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::MISOPins.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CLK Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CLKPins.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Number of Outputs
This property is of type Fixed list of ints and can be referenced with the variable name NumOutputs.
Number of Taps
This property is of type Fixed list of ints and can be referenced with the variable name NumTaps.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimulateComms.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
