Component: MQTT Client (Comms: System)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Comms: System |
MQTT Client component
A component providing access to MQTT IoT client. The client can connect to a MQTT server such as ThingSpeak. Allowing IoT type data to be published and read back.
The MQTT component requires connection to a Network Comms component via the "Network Component" property, to provide the bridge for simulated TCP/IP communication.
The Network Comms component can then be linked to an embedded TCP/IP component to provide embedded TCP/IP support.
Here is a typical setup for using MQTT on a Raspberry Pi.
Local Weather
A simple example demonstrating how to use MQTT with Flowcode SCADA to get the local weather conditions.
The example shows temperatures from Halifax in the UK and from Sydney in Australia.
Publish and Subscribe
A simple example to combine together an embedded device and a SCADA application.
Firstly we have an embedded Raspberry Pi project connected to an I2C Sensor, the sensor is sampled and the data is published to a MQTT server.
Next we subscribe to the data and receive it back into Flowcode SCADA.
GetTopic
Get the Topic of the last received (Read) packet.
Returns the number of bytes for the Topic
- <- STRING Topic
- BYTE Size
- Byte count the Topic buffer
ErrorAsString
- BYTE Error
Connect
Connect to the MQTT Server.
Returns the connected state.
0 if not connected, 1 if successful connection, or already connected.
Publish
Publish data to the server (broker)
Returns non-zero if successful
- <- STRING Topic
- <- STRING Payload
LastError
Returns the last error
Read
Read incoming data.
Returns non-zero if packet received.
Use GetTopic and GetPayload to read the contents.
Disconnect
Disconnects from the MQTT server and the network
Ping
Ping packet is sent to the Server and checks for a reply.
Returns non-zero value if successful
GetPayload
Get the Payload of the last received (Read) packet.
Returns the number of bytes for the Payload
- <- STRING Payload
- BYTE Size
- Byte count the Payload buffer
Subscribe
Subscribe to a Topic.
Must be Connected first
- <- STRING Topic
Unsubscribe
Unsubscribe from a Topic.
- <- STRING Topic
Simulation macro reference
Host
This property is of type Line of text and can be referenced with the variable name HOST.
Address of MQTT Broker
Port
This property is of type Unsigned integer and can be referenced with the variable name PORT.
Port used by MQTT Broker
Client identifier
This property is of type Line of text and can be referenced with the variable name CLIENT.
Client identifier
Network Timeout
This property is of type Unsigned integer and can be referenced with the variable name TIMEOUT.
Maximum time in mS to wait for network responses
Keep Alive
This property is of type Unsigned integer and can be referenced with the variable name KEEP_ALIVE.
The Keep Alive is the maximum time interval that is permitted to elapse
between the point at which the Client finishes transmitting one Control Packet
and the point it starts sending the next, measured in seconds.
Network Component
This property is of type Panel object and can be referenced with the variable name NETWORK_COMPONENT.
Pointer to the network communications component providing TCP simulation and abstraction for embedded
TCP modules.
