Component: TCPIP (Raspberry Pi) (Comms: Networking)
Revision as of 14:28, 18 September 2019 by BenR (talk | contribs) (→‎Examples)
Author Matrix Ltd.
Version 1.8 (Release)
Category Comms: Networking
Image TCPIP (Raspberry Pi) component
TCP/IP sockets component for use with Raspberry Pi. Raspberry Pi Only
Here is an example of using the TCP/IP component as a means to request data from a remote server on the internet or local network.
FC6 Icon.png Example RPI Client Request Data
Here is an example of using the TCP/IP component as a means to serve data to a client via the internet or local network.
FC6 Icon.png Example RPI HTML Webserver
Connect
Attempt to connect to the given address and port.
First open a socket on the local device using the Socket function and check that it is successful.
<- STRING Address
Remote destination address
This parameter may be returned back to the caller
UINT Port
Remote destination port
BYTE
Receive
Receive data into the data buffer.
Returns the number of bytes received
<- STRING Data
Data byte buffer to receive the data
UINT Count
Maximum number of bytes to read
UINT
SendTo
Send data to a destination host.
Returns the number of bytes sent.
<- STRING Data
Data byte buffer to send
UINT Count
Number of bytes to send
<- STRING Address
UINT Port
UINT
Send
Send data
<- STRING Data
UINT Count
UINT
Listen
Bind the socket to a port on the local host and set to listen mode.
UINT Port
BYTE
SocketOpen
Attempts to create a socket on the local device.
Type =0 for TCP, =1 for UDP
This must be successfully done before attempting connection with a remote destination.
Returns 1 if successful, 0 if not.
BYTE Type
Type of socket to create
BYTE
SocketClose
Close the socket
This macro has no parameters
AcceptOpen
BYTE
AcceptClose
Close the accept socket
Simulation macro reference
