Component: Network Communications (Comms: Networking)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Comms: Networking |
Network Communications component
A component designed to simplify the process of TCP/IP communications. Compatible with most of the Flowcode supported TCP/IP and WIFI components. A useful building block for creating components such as IoT and Modbus TCP.
Here are some examples showing the Network Communications component in action.
By itself the component provides a generic TCP/IP layer to drive the simulation runtime.
Here is a simple example showing the component used by itself to request data from a remote server on the internet.
Library Components
Components such as Webserver (GENERIC), MQTT and Modbus TCP can connect to and control the network comms layer.
Here is a simple example showing the component used with the Webserver (GENERIC) component.
Example Network Comms Web Server
Embedded Components
The Network Communications component can also be connected to embedded TCP/IP and WIFI style modules allowing for the abstraction to work with specific networking hardware modules.
Here is the current status of the Network Communications component with the various embedded modules.
Embedded Component | Other Variants of Component | Support Status |
[Component:_TCPIP_(Raspberry_Pi)_(Comms:_Networking) TCP/IP (Raspberry Pi)] | N/A | Fully Supported |
TCP/IP (W5500) | N/A | In Progress |
TCP/IP (NM7010A) | TCP/IP (EB023v1) | On Hold |
TCP/IP (W5100) | TCP/IP (EB023v2), TCP/IP (WIZ810MJ) | On Hold |
WLAN (ESP8266) | WLAN (ESP-12S), WIFI (BL0136), WIFI (ESP8266) | In Progress |
WLAN (WIZ610WI) | WIFI (EB069) | On Hold |
We are working through and adding support as and when we get chance so if you have a module that isn't listed or would like to try and prioritise a specific module then you can let us know via the user forums.
Connect
Connects to an IP address as a client on the specified port.
Some TCP/IP modules (RPI and ESP8266) will accept a URL instead of an IP address.
Returns: 0=Fail, 1=OK
- <- STRING Address
- IP address as a string e.g. "192.168.1.1" or URL on some TCP/IP modules
- UINT Port
- BOOL : Returns true if the operation is a success, else false
Receive
Attempts to receive up to a specified number of bytes from the active connection.
Returns the number of bytes received.
- <- STRING Data
- UINT Count
- Maximum number of bytes to read
Send
Sends the specified number of bytes via the active connection.
Returns the number of bytes sent, 0=Fail.
- <- STRING Data
- Array containing the data to send
- UINT Count
- Number of bytes to send from the data array
Listen
Bind the socket to a port on the local host and set to listen mode.
- UINT Port
SocketOpen
Attempts to create a socket on the local device.
This must be succesful to allow TCP/IP communications with a remote destination.
Returns: 0=Fail / 1=OK
SocketClose
Closes the current socket connection
Simulation macro reference
TCP/IP Component
This property is of type Panel object and can be referenced with the variable name Component.
Property to point to the TCP/IP or WIFI component you want to use.
If unconnected then default to simulated TCP/IP network communications using the PC network adapter.
Status
This property is of type Line of text and can be referenced with the variable name Status.
Informs the user of the current status of support for the connected component.
