Component: Injector (SCADA Slave Analog Input) (Comms Data Injectors)
Author | Matrix Ltd |
Version | 1.2 (Release) |
Category | Comms Data Injectors |
This inherits from Data Injector Template |
Injector (SCADA Slave Analog Input) component
Data injector to allow a physical analog input pin to be attached to a simulated component. The component will poll for any input state changes via SCADA Slave enabled hardware. Enabling the Flowcode simulation runtime to directly interface with a physical I/O pin.
This component does not contain any downloadable macros
Simulation macro reference
This component inherits simulation macros from Data Injector Template
InitialiseInjector
- <- STRING InjectorName
- Name of the console that will be created
RxByteCount
Returns the number of bytes currently sat in the receive buffer.
This call is provided by Data Injector Template
TxByte
- BYTE DataByte
RxByte
Attempt to receive a byte back from the injector
0 - 255 = Valid data
256 = RX timeout no data available
GetTxConsoleHandle
ChangeState
Sets the state of the bus.
SPI - Controls the chip select pin
I2C - Controls the start/restart/stop status
- BYTE State
- SPI: 0=CSLow, 1=CSHigh I2C: 0=Stop, 1=Start, 2=Restart, 3=LastRx
GetRxConsoleHandle
GetConsoleHandle
SCADA Slave
This property is of type Panel object and can be referenced with the variable name SCADASlave.
Number of Pins
This property is of type Fixed list of ints and can be referenced with the variable name NumPins.
Specifies the number of pins the component can monitor and control.
Poll Rate
This property is of type Fixed list of ints and can be referenced with the variable name PollRate.
Simulation ADC Pin
This property is of type Single analog pin and can be referenced with the variable name Pin0.
Pin monitored by the simulation
SCADA Slave ADC Pin
This property is of type Unsigned integer and can be referenced with the variable name SCADA_Pin0.
Pin used by the connected SCADA Slave hardware
Simulation ADC Pin
This property is of type Single analog pin and can be referenced with the variable name Pin1.
SCADA Slave ADC Pin
This property is of type Unsigned integer and can be referenced with the variable name SCADA_Pin1.
Simulation ADC Pin
This property is of type Single analog pin and can be referenced with the variable name Pin2.
SCADA Slave ADC Pin
This property is of type Unsigned integer and can be referenced with the variable name SCADA_Pin2.
Simulation ADC Pin
This property is of type Single analog pin and can be referenced with the variable name Pin3.
SCADA Slave ADC Pin
This property is of type Unsigned integer and can be referenced with the variable name SCADA_Pin3.
Simulation ADC Pin
This property is of type Single analog pin and can be referenced with the variable name Pin4.
SCADA Slave ADC Pin
This property is of type Unsigned integer and can be referenced with the variable name SCADA_Pin4.
Simulation ADC Pin
This property is of type Single analog pin and can be referenced with the variable name Pin5.
SCADA Slave ADC Pin
This property is of type Unsigned integer and can be referenced with the variable name SCADA_Pin5.
Simulation ADC Pin
This property is of type Single analog pin and can be referenced with the variable name Pin6.
SCADA Slave ADC Pin
This property is of type Unsigned integer and can be referenced with the variable name SCADA_Pin6.
Simulation ADC Pin
This property is of type Single analog pin and can be referenced with the variable name Pin7.
SCADA Slave ADC Pin
This property is of type Unsigned integer and can be referenced with the variable name SCADA_Pin7.
