MediaWiki API result
This is the HTML representation of the JSON format. HTML is good for debugging, but is unsuitable for application use.
Specify the format parameter to change the output format. To see the non-HTML representation of the JSON format, set format=json.
See the complete documentation, or the API help for more information.
{ "paraminfo": { "helpformat": "none", "modules": [ { "name": "allcategories", "classname": "ApiQueryAllCategories", "path": "query+allcategories", "group": "list", "prefix": "ac", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Allcategories" ], "parameters": [ { "index": 1, "name": "from", "type": "string" }, { "index": 2, "name": "continue", "type": "string" }, { "index": 3, "name": "to", "type": "string" }, { "index": 4, "name": "prefix", "type": "string" }, { "index": 5, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 6, "name": "min", "type": "integer" }, { "index": 7, "name": "max", "type": "integer" }, { "index": 8, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 9, "name": "prop", "default": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "size", "hidden" ] } ], "templatedparameters": [] }, { "name": "alldeletedrevisions", "classname": "ApiQueryAllDeletedRevisions", "path": "query+alldeletedrevisions", "group": "list", "prefix": "adr", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Alldeletedrevisions" ], "parameters": [ { "index": 1, "name": "prop", "default": "ids|timestamp|flags|comment|user", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "flags", "timestamp", "user", "userid", "size", "slotsize", "sha1", "slotsha1", "contentmodel", "comment", "parsedcomment", "content", "tags", "roles", "parsetree" ], "deprecatedvalues": [ "parsetree" ] }, { "index": 2, "name": "slots", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "main" ], "allspecifier": "*" }, { "index": 3, "name": "limit", "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 4, "name": "expandtemplates", "deprecated": "", "type": "boolean" }, { "index": 5, "name": "generatexml", "deprecated": "", "type": "boolean" }, { "index": 6, "name": "parse", "deprecated": "", "type": "boolean" }, { "index": 7, "name": "section", "type": "string" }, { "index": 8, "name": "diffto", "deprecated": "", "type": "string" }, { "index": 9, "name": "difftotext", "deprecated": "", "type": "string" }, { "index": 10, "name": "difftotextpst", "deprecated": "", "type": "boolean" }, { "index": 11, "name": "contentformat", "deprecated": "", "type": [ "text/x-wiki", "text/javascript", "application/json", "text/css", "text/plain" ] }, { "index": 12, "name": "user", "type": "user" }, { "index": 13, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 14, "name": "start", "type": "timestamp", "info": [ { "name": "useronly" } ] }, { "index": 15, "name": "end", "type": "timestamp", "info": [ { "name": "useronly" } ] }, { "index": 16, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 17, "name": "from", "type": "string", "info": [ { "name": "nonuseronly" } ] }, { "index": 18, "name": "to", "type": "string", "info": [ { "name": "nonuseronly" } ] }, { "index": 19, "name": "prefix", "type": "string", "info": [ { "name": "nonuseronly" } ] }, { "index": 20, "name": "excludeuser", "type": "user", "info": [ { "name": "nonuseronly" } ] }, { "index": 21, "name": "tag", "type": "string" }, { "index": 22, "name": "continue", "type": "string" }, { "index": 23, "name": "generatetitles", "type": "boolean" } ], "templatedparameters": [] }, { "name": "allfileusages", "classname": "ApiQueryAllLinks", "path": "query+allfileusages", "group": "list", "prefix": "af", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Allfileusages" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" }, { "index": 2, "name": "from", "type": "string" }, { "index": 3, "name": "to", "type": "string" }, { "index": 4, "name": "prefix", "type": "string" }, { "index": 5, "name": "unique", "type": "boolean" }, { "index": 6, "name": "prop", "default": "title", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title" ] }, { "index": 7, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 8, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "allimages", "classname": "ApiQueryAllImages", "path": "query+allimages", "group": "list", "prefix": "ai", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Allimages" ], "parameters": [ { "index": 1, "name": "sort", "default": "name", "type": [ "name", "timestamp" ] }, { "index": 2, "name": "dir", "default": "ascending", "type": [ "ascending", "descending", "newer", "older" ] }, { "index": 3, "name": "from", "type": "string" }, { "index": 4, "name": "to", "type": "string" }, { "index": 5, "name": "continue", "type": "string" }, { "index": 6, "name": "start", "type": "timestamp" }, { "index": 7, "name": "end", "type": "timestamp" }, { "index": 8, "name": "prop", "default": "timestamp|url", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "timestamp", "user", "userid", "comment", "parsedcomment", "canonicaltitle", "url", "size", "dimensions", "sha1", "mime", "mediatype", "metadata", "commonmetadata", "extmetadata", "bitdepth", "badfile" ] }, { "index": 9, "name": "prefix", "type": "string" }, { "index": 10, "name": "minsize", "type": "integer" }, { "index": 11, "name": "maxsize", "type": "integer" }, { "index": 12, "name": "sha1", "type": "string" }, { "index": 13, "name": "sha1base36", "type": "string" }, { "index": 14, "name": "user", "type": "user" }, { "index": 15, "name": "filterbots", "default": "all", "type": [ "all", "bots", "nobots" ] }, { "index": 16, "name": "mime", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 17, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 } ], "templatedparameters": [] }, { "name": "alllinks", "classname": "ApiQueryAllLinks", "path": "query+alllinks", "group": "list", "prefix": "al", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Alllinks" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" }, { "index": 2, "name": "from", "type": "string" }, { "index": 3, "name": "to", "type": "string" }, { "index": 4, "name": "prefix", "type": "string" }, { "index": 5, "name": "unique", "type": "boolean" }, { "index": 6, "name": "prop", "default": "title", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title" ] }, { "index": 7, "name": "namespace", "default": 0, "type": "namespace", "extranamespaces": [ -2, -1 ] }, { "index": 8, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 9, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "allmessages", "classname": "ApiQueryAllMessages", "path": "query+allmessages", "group": "meta", "prefix": "am", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Allmessages" ], "parameters": [ { "index": 1, "name": "messages", "default": "*", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 2, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "default" ] }, { "index": 3, "name": "enableparser", "type": "boolean" }, { "index": 4, "name": "nocontent", "type": "boolean" }, { "index": 5, "name": "includelocal", "type": "boolean" }, { "index": 6, "name": "args", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "allowsduplicates": "", "type": "string" }, { "index": 7, "name": "filter", "type": "string" }, { "index": 8, "name": "customised", "default": "all", "type": [ "all", "modified", "unmodified" ] }, { "index": 9, "name": "lang", "type": "string" }, { "index": 10, "name": "from", "type": "string" }, { "index": 11, "name": "to", "type": "string" }, { "index": 12, "name": "title", "type": "string" }, { "index": 13, "name": "prefix", "type": "string" } ], "templatedparameters": [] }, { "name": "allpages", "classname": "ApiQueryAllPages", "path": "query+allpages", "group": "list", "prefix": "ap", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Allpages" ], "parameters": [ { "index": 1, "name": "from", "type": "string" }, { "index": 2, "name": "continue", "type": "string" }, { "index": 3, "name": "to", "type": "string" }, { "index": 4, "name": "prefix", "type": "string" }, { "index": 5, "name": "namespace", "default": 0, "type": "namespace" }, { "index": 6, "name": "filterredir", "default": "all", "type": [ "all", "redirects", "nonredirects" ] }, { "index": 7, "name": "minsize", "type": "integer" }, { "index": 8, "name": "maxsize", "type": "integer" }, { "index": 9, "name": "prtype", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "edit", "move", "upload" ] }, { "index": 10, "name": "prlevel", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "", "autoconfirmed", "sysop" ] }, { "index": 11, "name": "prfiltercascade", "default": "all", "type": [ "cascading", "noncascading", "all" ] }, { "index": 12, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 13, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 14, "name": "filterlanglinks", "default": "all", "type": [ "withlanglinks", "withoutlanglinks", "all" ] }, { "index": 15, "name": "prexpiry", "default": "all", "type": [ "indefinite", "definite", "all" ] } ], "templatedparameters": [] }, { "name": "allredirects", "classname": "ApiQueryAllLinks", "path": "query+allredirects", "group": "list", "prefix": "ar", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Allredirects" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" }, { "index": 2, "name": "from", "type": "string" }, { "index": 3, "name": "to", "type": "string" }, { "index": 4, "name": "prefix", "type": "string" }, { "index": 5, "name": "unique", "type": "boolean" }, { "index": 6, "name": "prop", "default": "title", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title", "fragment", "interwiki" ] }, { "index": 7, "name": "namespace", "default": 0, "type": "namespace", "extranamespaces": [ -2, -1 ] }, { "index": 8, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 9, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "allrevisions", "classname": "ApiQueryAllRevisions", "path": "query+allrevisions", "group": "list", "prefix": "arv", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Allrevisions" ], "parameters": [ { "index": 1, "name": "prop", "default": "ids|timestamp|flags|comment|user", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "flags", "timestamp", "user", "userid", "size", "slotsize", "sha1", "slotsha1", "contentmodel", "comment", "parsedcomment", "content", "tags", "roles", "parsetree" ], "deprecatedvalues": [ "parsetree" ] }, { "index": 2, "name": "slots", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "main" ], "allspecifier": "*" }, { "index": 3, "name": "limit", "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 4, "name": "expandtemplates", "deprecated": "", "type": "boolean" }, { "index": 5, "name": "generatexml", "deprecated": "", "type": "boolean" }, { "index": 6, "name": "parse", "deprecated": "", "type": "boolean" }, { "index": 7, "name": "section", "type": "string" }, { "index": 8, "name": "diffto", "deprecated": "", "type": "string" }, { "index": 9, "name": "difftotext", "deprecated": "", "type": "string" }, { "index": 10, "name": "difftotextpst", "deprecated": "", "type": "boolean" }, { "index": 11, "name": "contentformat", "deprecated": "", "type": [ "text/x-wiki", "text/javascript", "application/json", "text/css", "text/plain" ] }, { "index": 12, "name": "user", "type": "user" }, { "index": 13, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 14, "name": "start", "type": "timestamp" }, { "index": 15, "name": "end", "type": "timestamp" }, { "index": 16, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 17, "name": "excludeuser", "type": "user" }, { "index": 18, "name": "continue", "type": "string" }, { "index": 19, "name": "generatetitles", "type": "boolean" } ], "templatedparameters": [] }, { "name": "alltransclusions", "classname": "ApiQueryAllLinks", "path": "query+alltransclusions", "group": "list", "prefix": "at", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Alltransclusions" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" }, { "index": 2, "name": "from", "type": "string" }, { "index": 3, "name": "to", "type": "string" }, { "index": 4, "name": "prefix", "type": "string" }, { "index": 5, "name": "unique", "type": "boolean" }, { "index": 6, "name": "prop", "default": "title", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title" ] }, { "index": 7, "name": "namespace", "default": 10, "type": "namespace", "extranamespaces": [ -2, -1 ] }, { "index": 8, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 9, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "allusers", "classname": "ApiQueryAllUsers", "path": "query+allusers", "group": "list", "prefix": "au", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Allusers" ], "parameters": [ { "index": 1, "name": "from", "type": "string" }, { "index": 2, "name": "to", "type": "string" }, { "index": 3, "name": "prefix", "type": "string" }, { "index": 4, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 5, "name": "group", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "bot", "sysop", "interface-admin", "bureaucrat", "suppress" ] }, { "index": 6, "name": "excludegroup", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "bot", "sysop", "interface-admin", "bureaucrat", "suppress" ] }, { "index": 7, "name": "rights", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "apihighlimits", "applychangetags", "autoconfirmed", "autocreateaccount", "autopatrol", "bigdelete", "block", "blockemail", "bot", "browsearchive", "changetags", "createaccount", "createpage", "createtalk", "delete", "deletechangetags", "deletedhistory", "deletedtext", "deletelogentry", "deleterevision", "edit", "editcontentmodel", "editinterface", "editprotected", "editmyoptions", "editmyprivateinfo", "editmyusercss", "editmyuserjson", "editmyuserjs", "editmyuserjsredirect", "editmywatchlist", "editsemiprotected", "editsitecss", "editsitejson", "editsitejs", "editusercss", "edituserjson", "edituserjs", "hideuser", "import", "importupload", "ipblock-exempt", "managechangetags", "markbotedits", "mergehistory", "minoredit", "move", "movefile", "move-categorypages", "move-rootuserpages", "move-subpages", "nominornewtalk", "noratelimit", "override-export-depth", "pagelang", "patrol", "patrolmarks", "protect", "purge", "read", "reupload", "reupload-own", "reupload-shared", "rollback", "sendemail", "siteadmin", "suppressionlog", "suppressredirect", "suppressrevision", "unblockself", "undelete", "unwatchedpages", "upload", "upload_by_url", "userrights", "userrights-interwiki", "viewmyprivateinfo", "viewmywatchlist", "viewsuppressed", "writeapi", "datatransferimport" ] }, { "index": 8, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "blockinfo", "groups", "implicitgroups", "rights", "editcount", "registration", "centralids" ] }, { "index": 9, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 10, "name": "witheditsonly", "type": "boolean" }, { "index": 11, "name": "activeusers", "type": "boolean" }, { "index": 12, "name": "attachedwiki", "type": "string" } ], "templatedparameters": [] }, { "name": "authmanagerinfo", "classname": "ApiQueryAuthManagerInfo", "path": "query+authmanagerinfo", "group": "meta", "prefix": "ami", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Authmanagerinfo" ], "parameters": [ { "index": 1, "name": "securitysensitiveoperation", "type": "string" }, { "index": 2, "name": "requestsfor", "type": [ "login", "login-continue", "create", "create-continue", "link", "link-continue", "change", "remove", "unlink" ] }, { "index": 3, "name": "mergerequestfields", "type": "boolean" }, { "index": 4, "name": "messageformat", "default": "wikitext", "type": [ "html", "wikitext", "raw", "none" ] } ], "templatedparameters": [] }, { "name": "backlinks", "classname": "ApiQueryBacklinks", "path": "query+backlinks", "group": "list", "prefix": "bl", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Backlinks" ], "parameters": [ { "index": 1, "name": "title", "type": "string" }, { "index": 2, "name": "pageid", "type": "integer" }, { "index": 3, "name": "continue", "type": "string" }, { "index": 4, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 5, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 6, "name": "filterredir", "default": "all", "type": [ "all", "redirects", "nonredirects" ] }, { "index": 7, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 8, "name": "redirect", "type": "boolean" } ], "templatedparameters": [] }, { "name": "blocks", "classname": "ApiQueryBlocks", "path": "query+blocks", "group": "list", "prefix": "bk", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Blocks" ], "parameters": [ { "index": 1, "name": "start", "type": "timestamp" }, { "index": 2, "name": "end", "type": "timestamp" }, { "index": 3, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 4, "name": "ids", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "integer" }, { "index": 5, "name": "users", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "user" }, { "index": 6, "name": "ip", "type": "string" }, { "index": 7, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 8, "name": "prop", "default": "id|user|by|timestamp|expiry|reason|flags", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "id", "user", "userid", "by", "byid", "timestamp", "expiry", "reason", "range", "flags", "restrictions" ] }, { "index": 9, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "account", "!account", "temp", "!temp", "ip", "!ip", "range", "!range" ] }, { "index": 10, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "categories", "classname": "ApiQueryCategories", "path": "query+categories", "group": "prop", "prefix": "cl", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Categories" ], "parameters": [ { "index": 1, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "sortkey", "timestamp", "hidden" ] }, { "index": 2, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "hidden", "!hidden" ] }, { "index": 3, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 4, "name": "continue", "type": "string" }, { "index": 5, "name": "categories", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 6, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "categoryinfo", "classname": "ApiQueryCategoryInfo", "path": "query+categoryinfo", "group": "prop", "prefix": "ci", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Categoryinfo" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "categorymembers", "classname": "ApiQueryCategoryMembers", "path": "query+categorymembers", "group": "list", "prefix": "cm", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Categorymembers" ], "parameters": [ { "index": 1, "name": "title", "type": "string" }, { "index": 2, "name": "pageid", "type": "integer" }, { "index": 3, "name": "prop", "default": "ids|title", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title", "sortkey", "sortkeyprefix", "type", "timestamp" ] }, { "index": 4, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 5, "name": "type", "default": "page|subcat|file", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "page", "subcat", "file" ] }, { "index": 6, "name": "continue", "type": "string" }, { "index": 7, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 8, "name": "sort", "default": "sortkey", "type": [ "sortkey", "timestamp" ] }, { "index": 9, "name": "dir", "default": "ascending", "type": [ "asc", "desc", "ascending", "descending", "newer", "older" ] }, { "index": 10, "name": "start", "type": "timestamp" }, { "index": 11, "name": "end", "type": "timestamp" }, { "index": 12, "name": "starthexsortkey", "type": "string" }, { "index": 13, "name": "endhexsortkey", "type": "string" }, { "index": 14, "name": "startsortkeyprefix", "type": "string" }, { "index": 15, "name": "endsortkeyprefix", "type": "string" }, { "index": 16, "name": "startsortkey", "deprecated": "", "type": "string" }, { "index": 17, "name": "endsortkey", "deprecated": "", "type": "string" } ], "templatedparameters": [] }, { "name": "contributors", "classname": "ApiQueryContributors", "path": "query+contributors", "group": "prop", "prefix": "pc", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Contributors" ], "parameters": [ { "index": 1, "name": "group", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "bot", "sysop", "interface-admin", "bureaucrat", "suppress" ] }, { "index": 2, "name": "excludegroup", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "bot", "sysop", "interface-admin", "bureaucrat", "suppress" ] }, { "index": 3, "name": "rights", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "apihighlimits", "applychangetags", "autoconfirmed", "autocreateaccount", "autopatrol", "bigdelete", "block", "blockemail", "bot", "browsearchive", "changetags", "createaccount", "createpage", "createtalk", "delete", "deletechangetags", "deletedhistory", "deletedtext", "deletelogentry", "deleterevision", "edit", "editcontentmodel", "editinterface", "editprotected", "editmyoptions", "editmyprivateinfo", "editmyusercss", "editmyuserjson", "editmyuserjs", "editmyuserjsredirect", "editmywatchlist", "editsemiprotected", "editsitecss", "editsitejson", "editsitejs", "editusercss", "edituserjson", "edituserjs", "hideuser", "import", "importupload", "ipblock-exempt", "managechangetags", "markbotedits", "mergehistory", "minoredit", "move", "movefile", "move-categorypages", "move-rootuserpages", "move-subpages", "nominornewtalk", "noratelimit", "override-export-depth", "pagelang", "patrol", "patrolmarks", "protect", "purge", "read", "reupload", "reupload-own", "reupload-shared", "rollback", "sendemail", "siteadmin", "suppressionlog", "suppressredirect", "suppressrevision", "unblockself", "undelete", "unwatchedpages", "upload", "upload_by_url", "userrights", "userrights-interwiki", "viewmyprivateinfo", "viewmywatchlist", "viewsuppressed", "writeapi", "datatransferimport" ] }, { "index": 4, "name": "excluderights", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "apihighlimits", "applychangetags", "autoconfirmed", "autocreateaccount", "autopatrol", "bigdelete", "block", "blockemail", "bot", "browsearchive", "changetags", "createaccount", "createpage", "createtalk", "delete", "deletechangetags", "deletedhistory", "deletedtext", "deletelogentry", "deleterevision", "edit", "editcontentmodel", "editinterface", "editprotected", "editmyoptions", "editmyprivateinfo", "editmyusercss", "editmyuserjson", "editmyuserjs", "editmyuserjsredirect", "editmywatchlist", "editsemiprotected", "editsitecss", "editsitejson", "editsitejs", "editusercss", "edituserjson", "edituserjs", "hideuser", "import", "importupload", "ipblock-exempt", "managechangetags", "markbotedits", "mergehistory", "minoredit", "move", "movefile", "move-categorypages", "move-rootuserpages", "move-subpages", "nominornewtalk", "noratelimit", "override-export-depth", "pagelang", "patrol", "patrolmarks", "protect", "purge", "read", "reupload", "reupload-own", "reupload-shared", "rollback", "sendemail", "siteadmin", "suppressionlog", "suppressredirect", "suppressrevision", "unblockself", "undelete", "unwatchedpages", "upload", "upload_by_url", "userrights", "userrights-interwiki", "viewmyprivateinfo", "viewmywatchlist", "viewsuppressed", "writeapi", "datatransferimport" ] }, { "index": 5, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 6, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "deletedrevisions", "classname": "ApiQueryDeletedRevisions", "path": "query+deletedrevisions", "group": "prop", "prefix": "drv", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Deletedrevisions" ], "parameters": [ { "index": 1, "name": "prop", "default": "ids|timestamp|flags|comment|user", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "flags", "timestamp", "user", "userid", "size", "slotsize", "sha1", "slotsha1", "contentmodel", "comment", "parsedcomment", "content", "tags", "roles", "parsetree" ], "deprecatedvalues": [ "parsetree" ] }, { "index": 2, "name": "slots", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "main" ], "allspecifier": "*" }, { "index": 3, "name": "limit", "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 4, "name": "expandtemplates", "deprecated": "", "type": "boolean" }, { "index": 5, "name": "generatexml", "deprecated": "", "type": "boolean" }, { "index": 6, "name": "parse", "deprecated": "", "type": "boolean" }, { "index": 7, "name": "section", "type": "string" }, { "index": 8, "name": "diffto", "deprecated": "", "type": "string" }, { "index": 9, "name": "difftotext", "deprecated": "", "type": "string" }, { "index": 10, "name": "difftotextpst", "deprecated": "", "type": "boolean" }, { "index": 11, "name": "contentformat", "deprecated": "", "type": [ "text/x-wiki", "text/javascript", "application/json", "text/css", "text/plain" ] }, { "index": 12, "name": "start", "type": "timestamp" }, { "index": 13, "name": "end", "type": "timestamp" }, { "index": 14, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 15, "name": "tag", "type": "string" }, { "index": 16, "name": "user", "type": "user" }, { "index": 17, "name": "excludeuser", "type": "user" }, { "index": 18, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "deletedrevs", "classname": "ApiQueryDeletedrevs", "path": "query+deletedrevs", "group": "list", "prefix": "dr", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "deprecated": "", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Deletedrevs" ], "parameters": [ { "index": 1, "name": "start", "type": "timestamp", "info": [ { "name": "modes", "values": [ 1, 2 ] } ] }, { "index": 2, "name": "end", "type": "timestamp", "info": [ { "name": "modes", "values": [ 1, 2 ] } ] }, { "index": 3, "name": "dir", "default": "older", "type": [ "newer", "older" ], "info": [ { "name": "modes", "values": [ 1, 3 ] } ] }, { "index": 4, "name": "from", "type": "string", "info": [ { "name": "modes", "values": [ 3 ] } ] }, { "index": 5, "name": "to", "type": "string", "info": [ { "name": "modes", "values": [ 3 ] } ] }, { "index": 6, "name": "prefix", "type": "string", "info": [ { "name": "modes", "values": [ 3 ] } ] }, { "index": 7, "name": "unique", "type": "boolean", "info": [ { "name": "modes", "values": [ 3 ] } ] }, { "index": 8, "name": "namespace", "default": 0, "type": "namespace", "info": [ { "name": "modes", "values": [ 3 ] } ] }, { "index": 9, "name": "tag", "type": "string" }, { "index": 10, "name": "user", "type": "user" }, { "index": 11, "name": "excludeuser", "type": "user" }, { "index": 12, "name": "prop", "default": "user|comment", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "revid", "parentid", "user", "userid", "comment", "parsedcomment", "minor", "len", "sha1", "content", "token", "tags" ] }, { "index": 13, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 14, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "duplicatefiles", "classname": "ApiQueryDuplicateFiles", "path": "query+duplicatefiles", "group": "prop", "prefix": "df", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Duplicatefiles" ], "parameters": [ { "index": 1, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 2, "name": "continue", "type": "string" }, { "index": 3, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 4, "name": "localonly", "type": "boolean" } ], "templatedparameters": [] }, { "name": "embeddedin", "classname": "ApiQueryBacklinks", "path": "query+embeddedin", "group": "list", "prefix": "ei", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Embeddedin" ], "parameters": [ { "index": 1, "name": "title", "type": "string" }, { "index": 2, "name": "pageid", "type": "integer" }, { "index": 3, "name": "continue", "type": "string" }, { "index": 4, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 5, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 6, "name": "filterredir", "default": "all", "type": [ "all", "redirects", "nonredirects" ] }, { "index": 7, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 } ], "templatedparameters": [] }, { "name": "extlinks", "classname": "ApiQueryExternalLinks", "path": "query+extlinks", "group": "prop", "prefix": "el", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Extlinks" ], "parameters": [ { "index": 1, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 2, "name": "continue", "type": "string" }, { "index": 3, "name": "protocol", "default": "", "type": [ "", "bitcoin", "ftp", "ftps", "geo", "git", "gopher", "http", "https", "irc", "ircs", "magnet", "mailto", "mms", "news", "nntp", "redis", "sftp", "sip", "sips", "sms", "ssh", "svn", "tel", "telnet", "urn", "worldwind", "xmpp" ] }, { "index": 4, "name": "query", "type": "string" }, { "index": 5, "name": "expandurl", "type": "boolean" } ], "templatedparameters": [] }, { "name": "exturlusage", "classname": "ApiQueryExtLinksUsage", "path": "query+exturlusage", "group": "list", "prefix": "eu", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Exturlusage" ], "parameters": [ { "index": 1, "name": "prop", "default": "ids|title|url", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title", "url" ] }, { "index": 2, "name": "continue", "type": "string" }, { "index": 3, "name": "protocol", "default": "", "type": [ "", "bitcoin", "ftp", "ftps", "geo", "git", "gopher", "http", "https", "irc", "ircs", "magnet", "mailto", "mms", "news", "nntp", "redis", "sftp", "sip", "sips", "sms", "ssh", "svn", "tel", "telnet", "urn", "worldwind", "xmpp" ] }, { "index": 4, "name": "query", "type": "string" }, { "index": 5, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 6, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 7, "name": "expandurl", "type": "boolean" } ], "templatedparameters": [] }, { "name": "filearchive", "classname": "ApiQueryFilearchive", "path": "query+filearchive", "group": "list", "prefix": "fa", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Filearchive" ], "parameters": [ { "index": 1, "name": "from", "type": "string" }, { "index": 2, "name": "to", "type": "string" }, { "index": 3, "name": "prefix", "type": "string" }, { "index": 4, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 5, "name": "sha1", "type": "string" }, { "index": 6, "name": "sha1base36", "type": "string" }, { "index": 7, "name": "prop", "default": "timestamp", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "sha1", "timestamp", "user", "size", "dimensions", "description", "parseddescription", "mime", "mediatype", "metadata", "bitdepth", "archivename" ] }, { "index": 8, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 9, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "filerepoinfo", "classname": "ApiQueryFileRepoInfo", "path": "query+filerepoinfo", "group": "meta", "prefix": "fri", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Filerepoinfo" ], "parameters": [ { "index": 1, "name": "prop", "default": "canUpload|displayname|favicon|initialCapital|local|name|rootUrl|scriptDirUrl|thumbUrl|url", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "canUpload", "displayname", "favicon", "initialCapital", "local", "name", "rootUrl", "scriptDirUrl", "thumbUrl", "url" ] } ], "templatedparameters": [] }, { "name": "fileusage", "classname": "ApiQueryBacklinksprop", "path": "query+fileusage", "group": "prop", "prefix": "fu", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Fileusage" ], "parameters": [ { "index": 1, "name": "prop", "default": "pageid|title|redirect", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "pageid", "title", "redirect" ] }, { "index": 2, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 3, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "redirect", "!redirect" ] }, { "index": 4, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 5, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "imageinfo", "classname": "ApiQueryImageInfo", "path": "query+imageinfo", "group": "prop", "prefix": "ii", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Imageinfo" ], "parameters": [ { "index": 1, "name": "prop", "default": "timestamp|user", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "timestamp", "user", "userid", "comment", "parsedcomment", "canonicaltitle", "url", "size", "dimensions", "sha1", "mime", "thumbmime", "mediatype", "metadata", "commonmetadata", "extmetadata", "archivename", "bitdepth", "uploadwarning", "badfile" ] }, { "index": 2, "name": "limit", "default": 1, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 3, "name": "start", "type": "timestamp" }, { "index": 4, "name": "end", "type": "timestamp" }, { "index": 5, "name": "urlwidth", "default": -1, "type": "integer" }, { "index": 6, "name": "urlheight", "default": -1, "type": "integer" }, { "index": 7, "name": "metadataversion", "default": "1", "type": "string" }, { "index": 8, "name": "extmetadatalanguage", "default": "en", "type": "string" }, { "index": 9, "name": "extmetadatamultilang", "type": "boolean" }, { "index": 10, "name": "extmetadatafilter", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 11, "name": "urlparam", "default": "", "type": "string" }, { "index": 12, "name": "badfilecontexttitle", "type": "string" }, { "index": 13, "name": "continue", "type": "string" }, { "index": 14, "name": "localonly", "type": "boolean" } ], "templatedparameters": [] }, { "name": "images", "classname": "ApiQueryImages", "path": "query+images", "group": "prop", "prefix": "im", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Images" ], "parameters": [ { "index": 1, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 2, "name": "continue", "type": "string" }, { "index": 3, "name": "images", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 4, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "imageusage", "classname": "ApiQueryBacklinks", "path": "query+imageusage", "group": "list", "prefix": "iu", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Imageusage" ], "parameters": [ { "index": 1, "name": "title", "type": "string" }, { "index": 2, "name": "pageid", "type": "integer" }, { "index": 3, "name": "continue", "type": "string" }, { "index": 4, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 5, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 6, "name": "filterredir", "default": "all", "type": [ "all", "redirects", "nonredirects" ] }, { "index": 7, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 8, "name": "redirect", "type": "boolean" } ], "templatedparameters": [] }, { "name": "info", "classname": "ApiQueryInfo", "path": "query+info", "group": "prop", "prefix": "in", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Info" ], "parameters": [ { "index": 1, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "protection", "talkid", "watched", "watchers", "visitingwatchers", "notificationtimestamp", "subjectid", "url", "readable", "preload", "displaytitle", "varianttitles" ], "deprecatedvalues": [ "readable" ] }, { "index": 2, "name": "testactions", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 3, "name": "testactionsdetail", "default": "boolean", "type": [ "boolean", "full", "quick" ] }, { "index": 4, "name": "token", "deprecated": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "edit", "delete", "protect", "move", "block", "unblock", "email", "import", "watch" ] }, { "index": 5, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "iwbacklinks", "classname": "ApiQueryIWBacklinks", "path": "query+iwbacklinks", "group": "list", "prefix": "iwbl", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Iwbacklinks" ], "parameters": [ { "index": 1, "name": "prefix", "type": "string" }, { "index": 2, "name": "title", "type": "string" }, { "index": 3, "name": "continue", "type": "string" }, { "index": 4, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 5, "name": "prop", "default": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "iwprefix", "iwtitle" ] }, { "index": 6, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "iwlinks", "classname": "ApiQueryIWLinks", "path": "query+iwlinks", "group": "prop", "prefix": "iw", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Iwlinks" ], "parameters": [ { "index": 1, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "url" ] }, { "index": 2, "name": "prefix", "type": "string" }, { "index": 3, "name": "title", "type": "string" }, { "index": 4, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 5, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 6, "name": "continue", "type": "string" }, { "index": 7, "name": "url", "deprecated": "", "type": "boolean" } ], "templatedparameters": [] }, { "name": "langbacklinks", "classname": "ApiQueryLangBacklinks", "path": "query+langbacklinks", "group": "list", "prefix": "lbl", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Langbacklinks" ], "parameters": [ { "index": 1, "name": "lang", "type": "string" }, { "index": 2, "name": "title", "type": "string" }, { "index": 3, "name": "continue", "type": "string" }, { "index": 4, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 5, "name": "prop", "default": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "lllang", "lltitle" ] }, { "index": 6, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "langlinks", "classname": "ApiQueryLangLinks", "path": "query+langlinks", "group": "prop", "prefix": "ll", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Langlinks" ], "parameters": [ { "index": 1, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "url", "langname", "autonym" ] }, { "index": 2, "name": "lang", "type": "string" }, { "index": 3, "name": "title", "type": "string" }, { "index": 4, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 5, "name": "inlanguagecode", "default": "en", "type": "string" }, { "index": 6, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 7, "name": "continue", "type": "string" }, { "index": 8, "name": "url", "deprecated": "", "type": "boolean" } ], "templatedparameters": [] }, { "name": "languageinfo", "classname": "ApiQueryLanguageinfo", "path": "query+languageinfo", "group": "meta", "prefix": "li", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [], "parameters": [ { "index": 1, "name": "prop", "default": "code", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "code", "bcp47", "dir", "autonym", "name", "fallbacks", "variants" ] }, { "index": 2, "name": "code", "default": "*", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 3, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "links", "classname": "ApiQueryLinks", "path": "query+links", "group": "prop", "prefix": "pl", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Links" ], "parameters": [ { "index": 1, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*", "extranamespaces": [ -2, -1 ] }, { "index": 2, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 3, "name": "continue", "type": "string" }, { "index": 4, "name": "titles", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 5, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "linkshere", "classname": "ApiQueryBacklinksprop", "path": "query+linkshere", "group": "prop", "prefix": "lh", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Linkshere" ], "parameters": [ { "index": 1, "name": "prop", "default": "pageid|title|redirect", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "pageid", "title", "redirect" ] }, { "index": 2, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 3, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "redirect", "!redirect" ] }, { "index": 4, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 5, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "logevents", "classname": "ApiQueryLogEvents", "path": "query+logevents", "group": "list", "prefix": "le", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Logevents" ], "parameters": [ { "index": 1, "name": "prop", "default": "ids|title|type|user|timestamp|comment|details", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title", "type", "user", "userid", "timestamp", "comment", "parsedcomment", "details", "tags" ] }, { "index": 2, "name": "type", "type": [ "", "block", "protect", "rights", "delete", "upload", "move", "import", "patrol", "merge", "suppress", "tag", "managetags", "contentmodel", "newusers", "create" ] }, { "index": 3, "name": "action", "type": [ "block/block", "block/reblock", "block/unblock", "contentmodel/change", "contentmodel/new", "create/create", "delete/delete", "delete/delete_redir", "delete/event", "delete/restore", "delete/revision", "import/interwiki", "import/upload", "managetags/activate", "managetags/create", "managetags/deactivate", "managetags/delete", "merge/merge", "move/move", "move/move_redir", "newusers/autocreate", "newusers/byemail", "newusers/create", "newusers/create2", "newusers/newusers", "patrol/autopatrol", "patrol/patrol", "protect/modify", "protect/move_prot", "protect/protect", "protect/unprotect", "rights/autopromote", "rights/rights", "suppress/block", "suppress/delete", "suppress/event", "suppress/reblock", "suppress/revision", "tag/update", "upload/overwrite", "upload/revert", "upload/upload" ] }, { "index": 4, "name": "start", "type": "timestamp" }, { "index": 5, "name": "end", "type": "timestamp" }, { "index": 6, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 7, "name": "user", "type": "user" }, { "index": 8, "name": "title", "type": "string" }, { "index": 9, "name": "namespace", "type": "namespace", "extranamespaces": [ -2, -1 ] }, { "index": 10, "name": "prefix", "type": "string" }, { "index": 11, "name": "tag", "type": "string" }, { "index": 12, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 13, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "mystashedfiles", "classname": "ApiQueryMyStashedFiles", "path": "query+mystashedfiles", "group": "list", "prefix": "msf", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:mystashedfiles" ], "parameters": [ { "index": 1, "name": "prop", "default": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "size", "type" ] }, { "index": 2, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 3, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "pagepropnames", "classname": "ApiQueryPagePropNames", "path": "query+pagepropnames", "group": "list", "prefix": "ppn", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Pagepropnames" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" }, { "index": 2, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 } ], "templatedparameters": [] }, { "name": "pageprops", "classname": "ApiQueryPageProps", "path": "query+pageprops", "group": "prop", "prefix": "pp", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Pageprops" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" }, { "index": 2, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" } ], "templatedparameters": [] }, { "name": "pageswithprop", "classname": "ApiQueryPagesWithProp", "path": "query+pageswithprop", "group": "list", "prefix": "pwp", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Pageswithprop" ], "parameters": [ { "index": 1, "name": "propname", "required": "", "type": "string" }, { "index": 2, "name": "prop", "default": "ids|title", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title", "value" ] }, { "index": 3, "name": "continue", "type": "string" }, { "index": 4, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 5, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "prefixsearch", "classname": "ApiQueryPrefixSearch", "path": "query+prefixsearch", "group": "list", "prefix": "ps", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Prefixsearch" ], "parameters": [ { "index": 1, "name": "search", "required": "", "type": "string" }, { "index": 2, "name": "namespace", "default": 0, "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 3, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 4, "name": "offset", "default": 0, "type": "integer" } ], "templatedparameters": [] }, { "name": "protectedtitles", "classname": "ApiQueryProtectedTitles", "path": "query+protectedtitles", "group": "list", "prefix": "pt", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Protectedtitles" ], "parameters": [ { "index": 1, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 2, "name": "level", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "autoconfirmed", "sysop" ] }, { "index": 3, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 4, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 5, "name": "start", "type": "timestamp" }, { "index": 6, "name": "end", "type": "timestamp" }, { "index": 7, "name": "prop", "default": "timestamp|level", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "timestamp", "user", "userid", "comment", "parsedcomment", "expiry", "level" ] }, { "index": 8, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "querypage", "classname": "ApiQueryQueryPage", "path": "query+querypage", "group": "list", "prefix": "qp", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Querypage" ], "parameters": [ { "index": 1, "name": "page", "required": "", "type": [ "Ancientpages", "BrokenRedirects", "Deadendpages", "DoubleRedirects", "ListDuplicatedFiles", "Listredirects", "Lonelypages", "Longpages", "MediaStatistics", "Mostcategories", "Mostimages", "Mostinterwikis", "Mostlinkedcategories", "Mostlinkedtemplates", "Mostlinked", "Mostrevisions", "Fewestrevisions", "Shortpages", "Uncategorizedcategories", "Uncategorizedpages", "Uncategorizedimages", "Uncategorizedtemplates", "Unusedcategories", "Unusedimages", "Wantedcategories", "Wantedfiles", "Wantedpages", "Wantedtemplates", "Unwatchedpages", "Unusedtemplates", "Withoutinterwiki" ] }, { "index": 2, "name": "offset", "default": 0, "type": "integer" }, { "index": 3, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 } ], "templatedparameters": [] }, { "name": "random", "classname": "ApiQueryRandom", "path": "query+random", "group": "list", "prefix": "rn", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Random" ], "parameters": [ { "index": 1, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 2, "name": "filterredir", "default": "nonredirects", "type": [ "all", "redirects", "nonredirects" ] }, { "index": 3, "name": "redirect", "deprecated": "", "type": "boolean" }, { "index": 4, "name": "limit", "default": 1, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 5, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "recentchanges", "classname": "ApiQueryRecentChanges", "path": "query+recentchanges", "group": "list", "prefix": "rc", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Recentchanges" ], "parameters": [ { "index": 1, "name": "start", "type": "timestamp" }, { "index": 2, "name": "end", "type": "timestamp" }, { "index": 3, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 4, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*", "extranamespaces": [ -2, -1 ] }, { "index": 5, "name": "user", "type": "user" }, { "index": 6, "name": "excludeuser", "type": "user" }, { "index": 7, "name": "tag", "type": "string" }, { "index": 8, "name": "prop", "default": "title|timestamp|ids", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "user", "userid", "comment", "parsedcomment", "flags", "timestamp", "title", "ids", "sizes", "redirect", "patrolled", "loginfo", "tags", "sha1" ] }, { "index": 9, "name": "token", "deprecated": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "patrol" ] }, { "index": 10, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "minor", "!minor", "bot", "!bot", "anon", "!anon", "redirect", "!redirect", "patrolled", "!patrolled", "unpatrolled", "autopatrolled", "!autopatrolled" ] }, { "index": 11, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 12, "name": "type", "default": "edit|new|log|categorize", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "edit", "new", "log", "external", "categorize" ] }, { "index": 13, "name": "toponly", "type": "boolean" }, { "index": 14, "name": "title", "type": "string" }, { "index": 15, "name": "continue", "type": "string" }, { "index": 16, "name": "generaterevisions", "type": "boolean" } ], "templatedparameters": [] }, { "name": "redirects", "classname": "ApiQueryBacklinksprop", "path": "query+redirects", "group": "prop", "prefix": "rd", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Redirects" ], "parameters": [ { "index": 1, "name": "prop", "default": "pageid|title", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "pageid", "title", "fragment" ] }, { "index": 2, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 3, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "fragment", "!fragment" ] }, { "index": 4, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 5, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "revisions", "classname": "ApiQueryRevisions", "path": "query+revisions", "group": "prop", "prefix": "rv", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Revisions" ], "parameters": [ { "index": 1, "name": "prop", "default": "ids|timestamp|flags|comment|user", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "flags", "timestamp", "user", "userid", "size", "slotsize", "sha1", "slotsha1", "contentmodel", "comment", "parsedcomment", "content", "tags", "roles", "parsetree" ], "deprecatedvalues": [ "parsetree" ] }, { "index": 2, "name": "slots", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "main" ], "allspecifier": "*" }, { "index": 3, "name": "limit", "type": "limit", "max": 500, "highmax": 5000, "min": 1, "info": [ { "name": "singlepageonly" } ] }, { "index": 4, "name": "expandtemplates", "deprecated": "", "type": "boolean" }, { "index": 5, "name": "generatexml", "deprecated": "", "type": "boolean" }, { "index": 6, "name": "parse", "deprecated": "", "type": "boolean" }, { "index": 7, "name": "section", "type": "string" }, { "index": 8, "name": "diffto", "deprecated": "", "type": "string" }, { "index": 9, "name": "difftotext", "deprecated": "", "type": "string" }, { "index": 10, "name": "difftotextpst", "deprecated": "", "type": "boolean" }, { "index": 11, "name": "contentformat", "deprecated": "", "type": [ "text/x-wiki", "text/javascript", "application/json", "text/css", "text/plain" ] }, { "index": 12, "name": "startid", "type": "integer", "info": [ { "name": "singlepageonly" } ] }, { "index": 13, "name": "endid", "type": "integer", "info": [ { "name": "singlepageonly" } ] }, { "index": 14, "name": "start", "type": "timestamp", "info": [ { "name": "singlepageonly" } ] }, { "index": 15, "name": "end", "type": "timestamp", "info": [ { "name": "singlepageonly" } ] }, { "index": 16, "name": "dir", "default": "older", "type": [ "newer", "older" ], "info": [ { "name": "singlepageonly" } ] }, { "index": 17, "name": "user", "type": "user", "info": [ { "name": "singlepageonly" } ] }, { "index": 18, "name": "excludeuser", "type": "user", "info": [ { "name": "singlepageonly" } ] }, { "index": 19, "name": "tag", "type": "string" }, { "index": 20, "name": "token", "deprecated": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "rollback" ] }, { "index": 21, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "search", "classname": "ApiQuerySearch", "path": "query+search", "group": "list", "prefix": "sr", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Search" ], "parameters": [ { "index": 1, "name": "search", "required": "", "type": "string" }, { "index": 2, "name": "namespace", "default": 0, "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 3, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 4, "name": "offset", "default": 0, "type": "integer" }, { "index": 5, "name": "what", "type": [ "title", "text", "nearmatch" ] }, { "index": 6, "name": "info", "default": "totalhits|suggestion|rewrittenquery", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "totalhits", "suggestion", "rewrittenquery" ] }, { "index": 7, "name": "prop", "default": "size|wordcount|timestamp|snippet", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "size", "wordcount", "timestamp", "snippet", "titlesnippet", "redirecttitle", "redirectsnippet", "sectiontitle", "sectionsnippet", "isfilematch", "categorysnippet", "score", "hasrelated", "extensiondata" ], "deprecatedvalues": [ "score", "hasrelated" ] }, { "index": 8, "name": "interwiki", "type": "boolean" }, { "index": 9, "name": "enablerewrites", "type": "boolean" }, { "index": 10, "name": "sort", "default": "relevance", "type": [ "relevance" ] } ], "templatedparameters": [] }, { "name": "siteinfo", "classname": "ApiQuerySiteinfo", "path": "query+siteinfo", "group": "meta", "prefix": "si", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Siteinfo" ], "parameters": [ { "index": 1, "name": "prop", "default": "general", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "general", "namespaces", "namespacealiases", "specialpagealiases", "magicwords", "interwikimap", "dbrepllag", "statistics", "usergroups", "libraries", "extensions", "fileextensions", "rightsinfo", "restrictions", "languages", "languagevariants", "skins", "extensiontags", "functionhooks", "showhooks", "variables", "protocols", "defaultoptions", "uploaddialog" ] }, { "index": 2, "name": "filteriw", "type": [ "local", "!local" ] }, { "index": 3, "name": "showalldb", "type": "boolean" }, { "index": 4, "name": "numberingroup", "type": "boolean" }, { "index": 5, "name": "inlanguagecode", "type": "string" } ], "templatedparameters": [] }, { "name": "stashimageinfo", "classname": "ApiQueryStashImageInfo", "path": "query+stashimageinfo", "group": "prop", "prefix": "sii", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Stashimageinfo" ], "parameters": [ { "index": 1, "name": "filekey", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 2, "name": "sessionkey", "deprecated": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 3, "name": "prop", "default": "timestamp|url", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "timestamp", "canonicaltitle", "url", "size", "dimensions", "sha1", "mime", "thumbmime", "metadata", "commonmetadata", "extmetadata", "bitdepth", "badfile" ] }, { "index": 4, "name": "urlwidth", "default": -1, "type": "integer" }, { "index": 5, "name": "urlheight", "default": -1, "type": "integer" }, { "index": 6, "name": "urlparam", "default": "", "type": "string" } ], "templatedparameters": [] }, { "name": "tags", "classname": "ApiQueryTags", "path": "query+tags", "group": "list", "prefix": "tg", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Tags" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" }, { "index": 2, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 3, "name": "prop", "default": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "displayname", "description", "hitcount", "defined", "source", "active" ] } ], "templatedparameters": [] }, { "name": "templates", "classname": "ApiQueryLinks", "path": "query+templates", "group": "prop", "prefix": "tl", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Templates" ], "parameters": [ { "index": 1, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*", "extranamespaces": [ -2, -1 ] }, { "index": 2, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 3, "name": "continue", "type": "string" }, { "index": 4, "name": "templates", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 5, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] } ], "templatedparameters": [] }, { "name": "tokens", "classname": "ApiQueryTokens", "path": "query+tokens", "group": "meta", "prefix": "", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Tokens" ], "parameters": [ { "index": 1, "name": "type", "default": "csrf", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "createaccount", "csrf", "login", "patrol", "rollback", "userrights", "watch" ] } ], "templatedparameters": [] }, { "name": "transcludedin", "classname": "ApiQueryBacklinksprop", "path": "query+transcludedin", "group": "prop", "prefix": "ti", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Transcludedin" ], "parameters": [ { "index": 1, "name": "prop", "default": "pageid|title|redirect", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "pageid", "title", "redirect" ] }, { "index": 2, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 3, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "redirect", "!redirect" ] }, { "index": 4, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 5, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "usercontribs", "classname": "ApiQueryUserContribs", "path": "query+usercontribs", "group": "list", "prefix": "uc", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Usercontribs" ], "parameters": [ { "index": 1, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 2, "name": "start", "type": "timestamp" }, { "index": 3, "name": "end", "type": "timestamp" }, { "index": 4, "name": "continue", "type": "string" }, { "index": 5, "name": "user", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "user" }, { "index": 6, "name": "userids", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "integer" }, { "index": 7, "name": "userprefix", "type": "string" }, { "index": 8, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 9, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 10, "name": "prop", "default": "ids|title|timestamp|comment|size|flags", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title", "timestamp", "comment", "parsedcomment", "size", "sizediff", "flags", "patrolled", "tags" ] }, { "index": 11, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "minor", "!minor", "patrolled", "!patrolled", "autopatrolled", "!autopatrolled", "top", "!top", "new", "!new" ] }, { "index": 12, "name": "tag", "type": "string" }, { "index": 13, "name": "toponly", "deprecated": "", "type": "boolean" } ], "templatedparameters": [] }, { "name": "userinfo", "classname": "ApiQueryUserInfo", "path": "query+userinfo", "group": "meta", "prefix": "ui", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Userinfo" ], "parameters": [ { "index": 1, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "blockinfo", "hasmsg", "groups", "groupmemberships", "implicitgroups", "rights", "changeablegroups", "options", "editcount", "ratelimits", "email", "realname", "acceptlang", "registrationdate", "unreadcount", "centralids", "preferencestoken", "latestcontrib" ], "deprecatedvalues": [ "preferencestoken" ] }, { "index": 2, "name": "attachedwiki", "type": "string" } ], "templatedparameters": [] }, { "name": "users", "classname": "ApiQueryUsers", "path": "query+users", "group": "list", "prefix": "us", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Users" ], "parameters": [ { "index": 1, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "blockinfo", "groups", "groupmemberships", "implicitgroups", "rights", "editcount", "registration", "emailable", "gender", "centralids", "cancreate" ] }, { "index": 2, "name": "attachedwiki", "type": "string" }, { "index": 3, "name": "users", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "string" }, { "index": 4, "name": "userids", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "integer" }, { "index": 5, "name": "token", "deprecated": "", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "userrights" ] } ], "templatedparameters": [] }, { "name": "watchlist", "classname": "ApiQueryWatchlist", "path": "query+watchlist", "group": "list", "prefix": "wl", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Watchlist" ], "parameters": [ { "index": 1, "name": "allrev", "type": "boolean" }, { "index": 2, "name": "start", "type": "timestamp" }, { "index": 3, "name": "end", "type": "timestamp" }, { "index": 4, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 5, "name": "user", "type": "user" }, { "index": 6, "name": "excludeuser", "type": "user" }, { "index": 7, "name": "dir", "default": "older", "type": [ "newer", "older" ] }, { "index": 8, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 9, "name": "prop", "default": "ids|title|flags", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "ids", "title", "flags", "user", "userid", "comment", "parsedcomment", "timestamp", "patrol", "sizes", "notificationtimestamp", "loginfo", "tags" ] }, { "index": 10, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "minor", "!minor", "bot", "!bot", "anon", "!anon", "patrolled", "!patrolled", "autopatrolled", "!autopatrolled", "unread", "!unread" ] }, { "index": 11, "name": "type", "default": "edit|new|log|categorize", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "edit", "new", "log", "external", "categorize" ] }, { "index": 12, "name": "owner", "type": "user" }, { "index": 13, "name": "token", "type": "string" }, { "index": 14, "name": "continue", "type": "string" } ], "templatedparameters": [] }, { "name": "watchlistraw", "classname": "ApiQueryWatchlistRaw", "path": "query+watchlistraw", "group": "list", "prefix": "wr", "source": "MediaWiki", "sourcename": "MediaWiki", "licensetag": "GPL-2.0-or-later", "licenselink": "https://www.flowcode.co.uk/wikiv9/index.php?title=Special:Version/License/MediaWiki", "readrights": "", "generator": "", "helpurls": [ "https://www.mediawiki.org/wiki/Special:MyLanguage/API:Watchlistraw" ], "parameters": [ { "index": 1, "name": "continue", "type": "string" }, { "index": 2, "name": "namespace", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": "namespace", "allspecifier": "*" }, { "index": 3, "name": "limit", "default": 10, "type": "limit", "max": 500, "highmax": 5000, "min": 1 }, { "index": 4, "name": "prop", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "changed" ] }, { "index": 5, "name": "show", "multi": "", "lowlimit": 50, "highlimit": 500, "limit": 50, "type": [ "changed", "!changed" ] }, { "index": 6, "name": "owner", "type": "user" }, { "index": 7, "name": "token", "type": "string" }, { "index": 8, "name": "dir", "default": "ascending", "type": [ "ascending", "descending" ] }, { "index": 9, "name": "fromtitle", "type": "string" }, { "index": 10, "name": "totitle", "type": "string" } ], "templatedparameters": [] } ] } }
