System Panel
The System Panel
Overview
When it opens, you see a central coloured square, called the Table top, set against a coloured background. The colours or images of both are set in the General Options. Gen Panel General Options 01.png
Table top
Camera control
  • Hold down the Ctrl key and click-drag the mouse to move the camera eye.
  • Hold down both the Ctrl and Shift keys and click-drag the mouse to move the camera target.
  • Hold down Alt and click anywhere on the panel to move the camera over that point or object.
Zoom
Gen Panel Camera Zoom.png There is also a zoom facility, operated by pressing the Ctrl key and moving the cursor over the viewpoint icon. Clicking the mouse button in this and dragging downwards causes the view to zoom out. Dragging upwards causes the view to zoom in. The same functionality can be achieved by holding Ctrl and using the mouse wheel.
Axis alignment
Hint:
Selecting items
They can then be grouped:
Shapes toolbar
Under the 2D section there is a 'Text' icon, used to 'drag and drop' a single row of alphanumeric characters onto the work area. Afterwards, you can select it, by clicking on it, and configure it using the Properties Panel. In particular, when added, you can edit the default text displayed using the bottom ‘Text’ control on the Properties panel. As well as text, there are also a few two-dimensional shapes available, such as; 'Ellipse' (circle), 'Rectangle', 'Rounded Rectangle' and finally a 'Line'.
Controls toolbar
Moving objects
Component controls
Gen Panel Object Move.png The left-hand end control allows you to move the selected object around the work area.
Gen Panel Object Stretch.png Moving to the right, the next control allows you to re-position a single point on an item. When you select an object and click on this control, pink anchors appear on the object. Selecting one of these allows it to be moved to a new position on the work area. The effect is to change the appearance, size or rotation of the object.
File:Gen Panel Object Resize 01.png The next control allows you to change the size of the object. After selecting an object and clicking on this control, a number of blue anchors appear on the object. Any of these can be dragged to re-size that particular dimension of the object. (Handles at the corners affect size in two dimensions.)
Gen Panel Object Rotate.png The fourth control allows you to rotate an object. After selecting it and clicking on this control, a number of yellow anchors appear on the object. These allow the object to be rotated around different axes. Corner anchors will spin the object.
Controlling the camera
Camera controls
Gen Panel Camera Pan.png The first allows the camera to pan left / right / up / down.
Gen Panel Camera Rotate.png The second allows the camera to rotate assuming the table top is the ground.
Gen Panel Camera Orbit.png The third allows the camera to rotate without considering the table top.
General Options
Gen Panel Object Collision Move Around.png The next control determines what happens when two objects ‘collide‘. The options are that they move through, move around or move over each other, with respect to the camera view.
Gen Panel Camera Align.png The next control is used to align the camera with the selected object.
Gen Panel Tools 01.png The first allows you to lock movement of objects:
  • To the grid,
  • To other objects,
  • To the table-top
Gen Panel General Options 01.png The second general options dialog is used to:
  • Set the colour or image of the display;
  • Set the number of views, allowing, for example, plan and elevation views of a component;
  • Set the level of detail of all the displays.
Multiple views
By selecting multiple views in the 'General Options' several camera angles can be displayed on the same image, enabling orthographic design of the system. Up to four views can be shown.
