Component: Level (DSP)
Revision as of 11:18, 28 July 2016 by BenR (talk | contribs)
Version 1.2 (Release)
Category DSP
Image Level component
Allows for detection and collection of peaks, troughs and averages.
Here is a basic example of the Level component. The example collects the max, min and average readings from the buffer and displays them on the LCD display.
FC6 Icon.png Level
The values in the buffer are defined using the InputADC component.
Min: Minimum (smallest) value read from the buffer.
Max: Maximum (largest) value read from the buffer.
Average: Rolling average calculated from the values inside the buffer.
ReadPeakTick
Returns the highest value from the last "Decay" number of index locations.
This macro has no parameters
UINT
ReadTrough
Returns the lowest value from the last "Decay" number of buffers.
UINT
ReadAverage
Returns the average from the last "Decay" number of buffers.
UINT
ReadAverageTick
Returns the average from the last "Decay" number of index locations.
UINT
ReadTroughTick
Returns the lowest value from the last "Decay" number of index locations.
UINT
ReadPeak
Returns the highest value from the last "Decay" number of buffers.
UINT
Simulation macro reference
Buffer Manager
This property is of type Fixed list of ints and can be referenced with the variable name buffer_manager.
Reference to DSP system buffer manager component.
Input
This property is of type Fixed list of ints and can be referenced with the variable name input_a.
Buffer assigned to input channel
Decay
This property is of type Signed integer and can be referenced with the variable name decay.
Configures how many buffers or values to allow a record to persist
