Component: Auto Version Identifier (Storage)
Revision as of 10:26, 9 May 2018 by BenR (talk | contribs) (XML import)
Version 1.2 (Release)
Category Storage
Image Auto Version Identifier component
Basic component designed to provide the program with the date and time of the build. Embedded assigns the time and date of compilation. Simulation assigns the time and date of the start of simulation.
GetTime
Returns the build time as a string
This macro has no parameters
STRING
GetDate
Returns the build date as a string
STRING
GetBuildNumber
Returns the current auto incremented built number property.
UINT
Simulation macro reference
Build Number
This property is of type Unsigned integer and can be referenced with the variable name BuildNumber.
Current build number, automatically incremented before each compilation takes place.
Date Divider
This property is of type Line of text and can be referenced with the variable name DateDivider.
Time Divider
This property is of type Line of text and can be referenced with the variable name TimeDivider.
Date Format
This property is of type Fixed list of ints and can be referenced with the variable name DateFormat.
Last Build Date
This property is of type Line of text and can be referenced with the variable name LastBuildDate.
Last Build Time
This property is of type Line of text and can be referenced with the variable name LastBuildTime.
