Component: DMX 512 Master (Comms: System)
Revision as of 14:50, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Author MatrixTSL
Version 2.0 (Release)
Category Comms: System
Image DMX_512 Master component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
DMX Master Example, reads the value of two ports using switch arrays to set the values and then transmits the data in a DMX packet. FC6 Icon.png DMX Master Example1 DMX Slave Example, captures the first DMX data channel sent from the Master and outputs the value onto a Port using the LED array component. FC6 Icon.png DMX Slave Example1
SetDataChannel
Sets the data byte in a data channel
UINT Channel
BYTE DataValue
SendDataChain
Transmits the BREAK, MAB and StartCode followed by the contents of the data channels.
BYTE StartCode
Configures the UART serial interface.
This macro has no parameters
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_uart::BAUD.
TX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::TX.
Data Channels
This property is of type Unsigned integer and can be referenced with the variable name DataChannels.
Number of data bytes used by the DMX chain, Max 512 bytes per transmission.
24 Bytes minimum to match minimum 1204us timing requirements, not all channels need to be used.
This property is of type True or false and can be referenced with the variable name cal_uart::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
   Simulation - draws an approximation of the UART data onto the scope trace.
   ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
This property is of type True or false and can be referenced with the variable name cal_uart::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name cal_uart::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::DataSource.
Simulation data source used to allow the component to connect to various remote devices
   Nothing - Simulation data is ignored
   COM port - Routes the communication data to and from a physical or virtual COM port
   Injector - Routes the communication data via a data injector component on the Panel.
