Component: DMX 512 Slave (Comms: System)
Revision as of 14:50, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Author MatrixTSL
Version 2.0 (Release)
Category Comms: System
Image DMX_512 Slave component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
DMX Master Example, reads the value of two ports using switch arrays to set the values and then transmits the data in a DMX packet. FC6 Icon.png DMX Master Example1 DMX Slave Example, captures the first DMX data channel sent from the Master and outputs the value onto a Port using the LED array component. FC6 Icon.png DMX Slave Example1
GetDataChannel
Gets the data byte from a data channel
UINT Channel
BYTE
ReceiveDataChain
Waits for a BREAK, MAB and StartCode followed by the contents of the data channels.
Returns 0 to indicate a timeout and 1 to indicate succesful reception.
BYTE Timeout
0 = Don't wait, 1 - 254 = 1ms - 254ms, 255 = Wait forever
BYTE
Configures the UART serial interface.
This macro has no parameters
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::CHANNEL.
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels.
Hardware channels use the selected peripheral on-board the target microcontroller.
RX
This property is of type Single digital pin and can be referenced with the variable name cal_uart::RX.
Baud Options
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_uart::BAUD.
Data Channels
This property is of type Unsigned integer and can be referenced with the variable name DataChannels.
Number of data bytes to receive from the master, Max 512 bytes per transmission.
24 Bytes minimum from Master to match minimum 1204us timing requirements, not all channels need to be used.
Start Channel
This property is of type Unsigned integer and can be referenced with the variable name StartChannel.
Channel from the master which we want to start taking our data channels
Use Start Code
This property is of type True or false and can be referenced with the variable name UseStart.
Do we wait for the start code or simply begin receiving data?
Start Code
This property is of type Unsigned integer and can be referenced with the variable name StartCode.
Start code value to listen out for, range 0-255
This property is of type True or false and can be referenced with the variable name cal_uart::ScopeTraces.
Selects if the scope traces are automatically added to the data recorder window or not.
   Simulation - draws an approximation of the UART data onto the scope trace.
   ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
This property is of type True or false and can be referenced with the variable name cal_uart::ConsoleData.
Console Columns
This property is of type Unsigned integer and can be referenced with the variable name cal_uart::ConsoleColumns.
Data Source
This property is of type Fixed list of ints and can be referenced with the variable name cal_uart::DataSource.
Simulation data source used to allow the component to connect to various remote devices
   Nothing - Simulation data is ignored
   COM port - Routes the communication data to and from a physical or virtual COM port
   Injector - Routes the communication data via a data injector component on the Panel.
