Component: RF 2.4GHz (nRF24L01) (Wireless)
Revision as of 14:51, 22 May 2018 by BenR (talk | contribs) (XML import - Pre 8.0 release)
Author Matrix Ltd.
Version 2.0 (Release)
Category Wireless
Image RF 2.4GHz (nRF24L01) component
A simple RF communications module based on the 2.4GHz nRF24L01 modules.
ReadRxByte
Reads a single byte back from the local Rx buffer.
BYTE Index
Byte to read, range 0 - 31
BYTE
WriteTxByte
Reads a single byte to the local Tx buffer.
BYTE Index
BYTE Value
FlushRx
Tells the RF module to flush the contents of the receive buffer.
Returns the status from sending the command.
This macro has no parameters
BYTE
ReadRxFifo
Reads the Rx FIFO buffer into a local buffer.
Use the ReadBuffer macro to collect the individual data bytes.
BYTE NumBytes
Number of bytes to try and read from the FIFO Range 1-32
WriteTxFifo
Writes the contents of the local Tx buffer to the Transmit FIFO.
BYTE NumBytes
Number of bytes to write to the FIFO, Range 1 - 32
FlushTx
Tells the RF module to flush the contents of the transmit buffer.
BYTE
CheckRX
Check the Rx FIFO status register for any new data.
Returns 0 = No data
Returns 1 = New data available
BYTE
ReadRegister
Reads a single bytes from the selected register.
Directly returns the value read back from the register.
BYTE Reg
Register address to access
BYTE
SetTxMode
Sets the module up ready to transmit data.
BYTE PA0
Pipe Address Bytes
BYTE PA1
Pipe Address Bytes
BYTE PA2
Pipe Address Bytes
BYTE PA3
Pipe Address Bytes
BYTE PA4
Pipe Address Bytes
SetRxMode
Sets the module up ready to receive data.
BYTE PA0
Pipe Address Bytes
BYTE PA1
Pipe Address Bytes
BYTE PA2
Pipe Address Bytes
BYTE PA3
Pipe Address Bytes
BYTE PA4
Pipe Address Bytes
WriteRegister
Writes a single byte to the selected register.
Returns the status of the write command.
BYTE Reg
BYTE Value
BYTE
Starts up and configures the RF module ready for use.
The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
UINT
Simulation macro reference
RF Channel
This property is of type Unsigned integer and can be referenced with the variable name RFChannel.
Sets the RF channel from 0 - 127 = 2.4000GHz - 2.525GHz
Both the transmitter and receiver should be on the same channel to receive data.
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
CE Pin
This property is of type Single digital pin and can be referenced with the variable name ce_pin.
Chip enable, configures RX or TX mode
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
