Component: Numeric Label (Indicators)
Revision as of 16:23, 27 November 2018 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Indicators
Image Numeric Label component
Allows a numeric label to be displayed on the user panel. Used for displaying the value of a variable during simulation runtime. Provides up to 5 customisable ranges to automatically alter the colour of the label based on the value.
This component does not contain any downloadable macros
Simulation macro reference
DisplayAsReal
Displays a floating point value on the label with a confiiguarable number of decimal points
FLOAT Value
Real floating point value to display
BYTE Precision
Number of decimal point values to show e.g. 2 = 0.00
SetBackgroundColour
Allows the user to manually specify the default colour of the background.
LONG Colour
RGB colour in the hexadecimal form 0xBBGGRR, -1 for Transparent
DisplayAsInt
Displays an integer value on the label.
Capable of displaying positive and negative values.
LONG Value
Integer value to display
SetForegroundColour
Allows the user to manually specify the default colour of the foreground text.
LONG Colour
SetUnits
Allows the user to manually specify the units string that is appended to the end of the label.
<- STRING Units
This parameter may be returned back to the caller
Show Title
This property is of type True or false and can be referenced with the variable name ShowTitle.
Decides if the title is shown on the panel.
Title Text
This property is of type Line of text and can be referenced with the variable name Title.
Specifies the title displayed on the panel.
Title Scale
This property is of type Floating point and can be referenced with the variable name TitleScale.
Specifies the size of the title on the panel, default 1.2
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgColTitle.
Specifies the foreground colour of the title text
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgColTitle.
Specifies the background colour of the title text
Label Scale
This property is of type Floating point and can be referenced with the variable name LabelScale.
Specifies the scale of the label text, default 1.0
Show Units
This property is of type True or false and can be referenced with the variable name ShowUnits.
Specifies if the unit text is appended to the end of the numeric value
Unit Text
This property is of type Line of text and can be referenced with the variable name UnitText.
Optionally adds a unit label to the end of the displays string
Colour Ranges
This property is of type Fixed list of ints and can be referenced with the variable name Range.
Allows ranges to be specified to automatically format the foreground and background colours based on the numeric value
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol.
The label foreground Text colour
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol.
The label background Surrounding colour
Min Value
This property is of type Floating point and can be referenced with the variable name MinVal1.
The minimum value to meet the range condition ( >= )
Max Value
This property is of type Floating point and can be referenced with the variable name MaxVal1.
The maximum value to meet the range condition ( < )
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol1.
The label foreground Text colour when in the specified range
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol1.
The label background highlight colour when in the specified range
Min Value
This property is of type Floating point and can be referenced with the variable name MinVal2.
Max Value
This property is of type Floating point and can be referenced with the variable name MaxVal2.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol2.
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol2.
Min Value
This property is of type Floating point and can be referenced with the variable name MinVal3.
Max Value
This property is of type Floating point and can be referenced with the variable name MaxVal3.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol3.
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol3.
Min Value
This property is of type Floating point and can be referenced with the variable name MinVal4.
Max Value
This property is of type Floating point and can be referenced with the variable name MaxVal4.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol4.
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol4.
Min Value
This property is of type Floating point and can be referenced with the variable name MinVal5.
Max Value
This property is of type Floating point and can be referenced with the variable name MaxVal5.
Foreground Colour
This property is of type Color picker with transparency and can be referenced with the variable name FgCol5.
Background Colour
This property is of type Color picker with transparency and can be referenced with the variable name BgCol5.
