Component: MULTIUART (SPI2UART) (Comms: System)
Revision as of 22:39, 20 December 2018 by BenR (talk | contribs)
Version 2.0 (Release)
Category Comms: System
Image MULTIUART (SPI2UART) component
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
FC6 Icon.png Simple test program
ReceiveByte
Returns the first received byte held in queue for the selected channel.
Recommended to use the CheckRx macro first to collect number of bytes.
BYTE UART
UART Index Range: 0-3
BYTE
TransmitString
Adds a byte to the transmit queue for the selected channel.
BYTE UART
<- STRING Data
This parameter may be returned back to the caller
SetBaud
BYTE UART
BYTE Baud
TransmitByte
BYTE UART
BYTE Data
CheckRx
Returns the number of received bytes held in queue for the selected channel.
BYTE UART
BYTE
ReceiveString
Returns a string of received bytes held in queue for the selected channel.
BYTE UART
BYTE NumBytes
STRING
CheckTx
Returns the number of bytes held in the transmit queue for the selected channel.
BYTE UART
BYTE
Activates the SPI peripheral and claims control over the I/O pins.
This macro has no parameters
Simulation macro reference
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::PR_SCALE.
Prescale option selector
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MOSI.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi::MISO.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Label used to identify the component on the panel.
This property is of type True or false and can be referenced with the variable name cal_spi::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_spi::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi::Injector.
