Dashboard Panel
Revision as of 08:41, 2 July 2019 by DavidA (talk | contribs)
The Dashboard Panel provides a framework on which to load Flowcode components that compliments the System Panel. It is designed to show the representation of abstract components such as dials and meters during simulation.
The Dashboard Panel
Overview
The Dashboard Panel is opened by selecting it in the View menu. Unlike the System Panel, the Dashboard panel gives only a top-down view of the components. Components are typically designed in the System Panel and then used during programming in the dashboard.
When the dashboard opens, you see a colored workspace. The color is set in the 'General Options'. GeneralOptionsIcon.png
Dashboard or System Panel?
Differences to the System panel
The Dashboard panel has a Controls toolbar running horizontally across the top. However, these have more limited functionality on the System Panel as the Dashboard is not designed for modelling objects or creating components.
Users can bring either 2D or 3D shapes onto the Dashboard Panel to create items such as control panels etc. This is done by adding a shape from the top components menu, just as you would a regular component.
Camera control
See the section Camera Control for more details on manipulating the camera and selecting objects.
Selecting items
They can then be grouped:
