Component: Magnetometer 3 Axis (HMC5883L) (Movement & Orientation)
Revision as of 09:17, 7 August 2019 by BenR (talk | contribs) (→‎Examples)
Version 1.6 (Release)
Category Movement & Orientation
Image Magnetometer 3_Axis (HMC5883L) component
HMC5883L 3-Axis Magnetometer sensor Useful for working out data such as compass orientation.
Here is a very simple demonstration on how to use the sensor to read X, Y, Z magnetometer data from the sensor.
FC6 Icon.png HMC5883L Demo
Read_Register
Reads a value from a register on the accelerometer.
BYTE Reg
BYTE
UpdateCompassData
Reads from the compass and updates the local XYZ variables.
Returns 1 for new data and 0 for no new data
This macro has no parameters
BYTE
Write_Register
Writes a data value to a specific register on the accelerometer
BYTE Reg
BYTE Data
BYTE
CollectXYZData
Collect the data from the local accelerometer buffers.
The Axis parameter specifies the Axis to be read.
0 / 'x' / 'X' - X axis
1 / 'y' / 'Y' - Y axis
2 / 'z' / 'Z' - Z axis
BYTE Axis
INT
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north.
Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West
Requires the ArcTan floating point function to be available to work correctly.
Supported on AVR, 16-bit
BYTE NumSamples
The number of readings to base the bearing on
UINT
Sets up up the communication bus and initialises the accelerometer module.
Returns 0 for success and > 0 for fail.
BYTE
Simulation macro reference
SimSetCompass
Allows the XYZ slider values to be set via the simulation
INT X
INT Y
INT Z
Bit Depth
This property is of type Signed integer and can be referenced with the variable name bit_depth.
Measurement Mode
This property is of type Fixed list of ints and can be referenced with the variable name MeasurementMode.
Continuous mode makes constant sensor readings setting the RDY pin when new data is available.
Single mode does a single sensor read setting the RDY pin when done and then waits for data to be read.
Num Samples
This property is of type Fixed list of ints and can be referenced with the variable name NumSamples.
The number of samples that are averaged together to provide the readings.
Compass Data Rate
This property is of type Fixed list of ints and can be referenced with the variable name compass_data_rate.
Sets the output conversion rate.
Compass Scale
This property is of type Fixed list of ints and can be referenced with the variable name compass_scale.
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::CHANNEL.
Channel selection
Baud Select
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::BAUD_LIST.
This property is of type Signed integer and can be referenced with the variable name cal_i2c::BAUD.
Baud rate to be used
Stop Delay
This property is of type True or false and can be referenced with the variable name cal_i2c::StopDel.
On older microcontroller devices there is a potential for the I2C hardware channel to lock up if there is not
a 10ms delay between an I2C stop event and the next I2C start event.
Most modern microcontrollers will not have a problem so this property can be disabled to speed up the
I2C communications.
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c::SCL.
Use RDY Pin
This property is of type True or false and can be referenced with the variable name UseRDY.
Simulation GUI
This property is of type True or false and can be referenced with the variable name SimulationGUI.
Yes: Accelerometer data will come from the simulation component sliders.
No: Accelerometer data will come from the I2C CAL component - Injector etc
This property is of type True or false and can be referenced with the variable name cal_i2c::ScopeTraces.
This property is of type True or false and can be referenced with the variable name cal_i2c::ConsoleData.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c::Injector.
