Component: Thermocouple (MAX31855) (Environmental)
Revision as of 12:00, 25 February 2020 by BenR (talk | contribs) (→‎Examples)
Version 1.0 (Release)
Category Environmental
Image Thermocouple (MAX31855) component
Component to interface the MAX31855 IC from MAXIM. Uses a standard 3-wire SPI interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Example program showing how to use the Thermocouple component. FC6 Icon.png MAX31855_Example
ReadReference_Int
Returns the reference temperature from the last sample as an integer value in Degrees C.
This macro has no parameters
INT
ReadReference_Float
Returns the reference temperature from the last sample as a floating point value in Degrees C.
FLOAT
Sample
Reads the memory of the MAX31855 IC and checks for errors.
Must be called before any of the Read functions.
Returns: 0=OK, 1=Open Circuit, 2=Short GND, 3=Short VCC
BYTE
ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value in Degrees C.
INT
ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value in Degrees C.
FLOAT
Configures the SPI bus ready for communications.
Simulation macro reference
Thermocouple Type
This property is of type Fixed list of ints and can be referenced with the variable name ThermocoupleType.
Specified at the end of the MAX part number MAX31855X where X is the Thermocouple type.
Selects which type of thermocouple the IC works with.
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CHANNEL.
SPI Channel selector
Prescale
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::PR_SCALE.
Prescale option selector
MOSI Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::MOSIPins.
MOSI
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MOSI.
MISO Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::MISOPins.
MISO
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::MISO.
CLK Remap Pin
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::CLKPins.
CLK
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::CLK.
CS / SS
This property is of type Single digital pin and can be referenced with the variable name cal_spi1::SS.
Chip Select / Slave Select Pin
Master Mode: General purpose output pin used to select the remote SPI device.
Slave Mode: Hardware chip select pin input used to select the SPI device.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimComms.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
Injector
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
