Component: STM32 Timer (Storage)
Revision as of 12:03, 25 February 2020 by BenR (talk | contribs) (XML import)
Version 1.1 (Release)
Category Storage
Image STM32 Timer component
Allows you to measure the passage of time via the use of the STM hardware timer. Works like a stopwatch with macros to start, stop and reset the timer counter. Returns time as integer Seconds, Milliseconds and also Floating Point and String.
GetCountSeconds
Returns the count value as a number of whole seconds, rounded down to the nearest second
This macro has no parameters
ULONG
StartCounter
Starts the timer counting.
BOOL ResetCounters
Range: 0-1 where 0=Do Not Reset and 1=Reset
GetCountString
Returns the count value as a floating point string in seconds.
BYTE Precision
Number of decimal places to display in string
STRING
GetCountMilliseconds
Returns the count value as a number of milliseconds
ULONG
StopCounter
Stops the timer counting.
ResetCounter
GetCountReal
Returns the count value as a floating point value in seconds.
FLOAT
GetRawCount
Returns the number of milliseconds elapsed since the timer was started.
ULONG
Simulation macro reference
Timer Delay (ms)
This property is of type Unsigned integer and can be referenced with the variable name TimerDelay.
Number of milliseconds between timer events which increment the simulated timer counter variable.
10ms will yield the highest resolution. Values less than this will likely just increase the error and making the timer run slow.
Higher delays will yield greater accuracy.
Decimal Points
This property is of type Unsigned integer and can be referenced with the variable name DecimalPoints.
