Component: XML JSON Parser (Runtime Tools)
Author | MatrixTSL |
Version | 1.0 (Release) |
Category | Runtime Tools |
XML JSON Parser component
A component designed to simplify the collection of data from XML and JSON sources. Parses the raw data and creates a dynamic representation of the data that is easy to navigate and interrogate. Also allows the objects to be manually created or edited and then re-exported as XML or JSON format.
This component does not contain any downloadable macros
Simulation macro reference
SetObjectString
Sets the data string of an existing object.
- HANDLE Object
- Handle to the object
- <- STRING Data
FindObject
Finds the first instance of an object.
Returns the first matching path from the root.
Returns 0 if the path was not found.
- <- STRING ObjPath
- e.g. "rss.channel.title"
GetRootHandle
Allows for user to step through the objects manually using the inbuilt runtime api calls.
FindObjectString
Searches for and then collects the data string from the specified path.
- <- STRING ObjPath
AddObject
Adds a tag at the selected location.
Use the GetRootHandle and runtime API Tree functions .
Returns the handle of the new object.
- HANDLE ParentObject
- The Object Handle to store the new tag inside
- <- STRING Tag
- Name of the object
- <- STRING Data
- data for the object (optional)
FindNextObject
Finds the next instance of an object following a GetObject* call.
Returns the first matching path from the last search.
- <- STRING SubObjPath
- e.g. "item.title"
ParseJSONDataString
Parses JSON formatted data in a piecemeal format as and when file data is available.
Creates objects to store the contents of the JSON
- <- STRING Data
- JSON Data string, can be a chunk of a file at a time
- UINT Length
- Number of Bytes to process
GetObjectString
Collects the data string from the specified object.
- HANDLE Object
ClearObjects
Deletes all object data ready for fresh input
GetObjectTag
Collects the tag string from the specified object.
- HANDLE Object
DeleteObject
Deletes a selected tag object.
- HANDLE Object
- BOOL : Returns true if the operation is a success, else false
FindNextObjectString
- e.g. "item.title"
SetObjectTag
Sets the tag name of an existing object.
- HANDLE Object
- <- STRING Tag
ParseXMLDataString
Parses XML formatted data in a piecemeal format as and when file data is available.
Creates objects to store the contents of the XML.
- <- STRING Data
- XML Data string, can be a chunk of a file at a time
- UINT Length
- Number of bytes to process
This component does not contain any properties
