Component: Circular Buffer (Float) (Storage)
Author | Matrix Ltd |
Version | 1.5 (Release) |
Category | Storage |
Circular Buffer (Float) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data storage. Also features macros to allow you to check for specific floating point values.
WaitForValues
Waits for an array of values to appear in the circular buffer.
Returns 0 to indicate a timeout.
Returns 1 to indicate the data has been found.
- FLOAT Values
- BYTE NumValues
- Number of values to try and look for
- BYTE RemoveContent
- 0=Leave the buffer contents untouched, 1=Remove values as you go
- UINT Timeout
- Max amount of time to wait in milliseconds before returning 0=WaitForever
GetNumberValues
Returns the number of valid 16-bit data values currently stored inside the buffer.
PeekData
Reads the next available 16-bit data value from the circular buffer without advancing the current index,
Returns the default value if the buffer is empty.
PutData
Add a 32-bit floating point value to the next free location inside the circular buffer.
If the data goes into the buffer correctly then return 1.
Otherwise the buffer is full and the return value will equal 0.
- FLOAT Data
LookForValues
Scans the buffer for an array of specific values.
Returns 0 if the value is not found.
Returns 1 if the value is found.
- FLOAT Values
- BYTE NumValues
- The number of values you wish to try and match
- 0=Leave data alone, 1=Remove data from buffer
- BYTE ResetFind
- 0=Continue the find from the last operation, 1=Start again
GetData
Reads the next available 32-bit floating point value from the circular buffer,
FlushBuffer
Clears the contents of the buffer and re-initialises the index locations.
GetIndexedValue
Gets the value of a single 32-bit floating point value at a known location in the buffer.
Leaves the buffer contents and pointers untouched.
- UINT address
Simulation macro reference
Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name BufferSize.
Sets the number of byte elements inside the circular buffer.
Storage Type
This property is of type Fixed list of ints and can be referenced with the variable name StorageType.
When buffer is full this property decides what to do.
Store first x values - Will retain the information inside the buffer, new data will be discarded.
Store last x values - Will discard the oldest location in the buffer and overwrite with new data.
Memory Type
This property is of type Fixed list of ints and can be referenced with the variable name MemType.
Default Return Data
This property is of type Floating point and can be referenced with the variable name RETURN.
Specifies the value returned by the receive function when there is no data held in the buffer
