Component: Output Digital (DSP)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Version 1.2 (Release)
Category DSP
Image Output Digital component
Allows the values from a buffer to be read. Either a value at a time or as an array.
GetIntArray
Returns an array of values from the specified buffer and scales it appropriatley if required.
Auto increments the read location.
UINT Data
UINT Count
GetLongArray
ULONG Data
UINT Count
GetLong
Returns a value from the specified buffer and scales it appropriatley if required.
This macro has no parameters
ULONG
GetInt
UINT
GetByteArray
BYTE Data
UINT Count
GetByte
BYTE
Simulation macro reference
Connect To
This property is of type Panel object and can be referenced with the variable name ConnectTo.
