Component: Offset (DSP)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Version 1.1 (Release)
Category DSP
Image Offset component
Allows the values in a single buffer to be offset uniformly. Functions include: Add, Subtract
Calculate
Performs the selected offset on a value from the input buffer and passes to the output buffer.
This macro has no parameters
CalculateArray
Performs the selected offset on an entire buffer.
SetOffset
Sets the Offset to be used when calling the calculate function.
INT Offset
Simulation macro reference
Connect To
This property is of type Panel object and can be referenced with the variable name ConnectTo.
Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name BuffSize.
Buffer Type
This property is of type Fixed list of ints and can be referenced with the variable name BuffType.
Sets the buffer data type.
Offset Type
This property is of type Fixed list of ints and can be referenced with the variable name OffsetType.
Defines the type of calculation performed on the input buffer to obtain the output value.
A left shift is essentially an optimised multiply with the multiplier being the 2^scaler
A right shift is essentially an optimised divide with the divider being the 2^scaler
Rollover
This property is of type True or false and can be referenced with the variable name Rollover.
Allow the output buffer to rollover.
For example 128 + 128 = 256 which would equate to 0 using an 8-bit buffer with rollover enabled.
With rollover disabled the output would be set to 255 which is the max representable value.
Initial Offset
This property is of type Signed integer and can be referenced with the variable name InitialOffset.
