Component: Output DAC (DSP)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Version 1.2 (Release)
Category DSP
Image Output DAC component
Allows the values from a buffer to be passed directly to an internal DAC output.
OutputDACArray
Outputs an array of values from the input buffer appropriatley scaled to suit the DAC.
UINT Delay
Delay in microseconds between outputting each sample.
ControlDAC
Enable or disable the DAC output,
Disabled by default.
BOOL State
OutputDAC
Outputs a single value from the input buffer appropriatley scaled to suit the DAC.
This macro has no parameters
Simulation macro reference
Connect To
This property is of type Panel object and can be referenced with the variable name ConnectTo.
This property is of type Fixed list of ints and can be referenced with the variable name DAC_Output1::CHANNEL.
DAC Channel number
DAC Output Pin
This property is of type Single digital pin and can be referenced with the variable name DAC_Output1::PORT.
DAC Output Pin
Vref Option
This property is of type Fixed list of ints and can be referenced with the variable name DAC_Output1::VREFOP.
Vref Voltage
This property is of type Floating point and can be referenced with the variable name DAC_Output1::VrefVol.
Control Bits
This property is of type Signed integer and can be referenced with the variable name DAC_Output1::BITS.
Resolution
This property is of type Line of text and can be referenced with the variable name DAC_Output1::Res.
Voltage Resolution
This property is of type Floating point and can be referenced with the variable name DAC_Output1::VoltRes.
