Component: Interlace (DSP)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Version 1.2 (Release)
Category DSP
Image Interlace component
Allows multiple input buffers to be interlaced together into a single output buffer. Useful for combining several streams together for sending out via communications or storing.
Interlace
Collects a single value from each of the connected input buffers and places in order into the output buffer.
This macro has no parameters
InterlaceArray
Repeats the interlace function as many times as set in the data count property.
Simulation macro reference
Connect To 0
This property is of type Panel object and can be referenced with the variable name ConnectTo.
Connect To 1
This property is of type Panel object and can be referenced with the variable name ConnectTo2.
Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name BuffSize.
Buffer Type
This property is of type Fixed list of ints and can be referenced with the variable name BuffType.
Sets the buffer data type.
Number of Inputs
This property is of type Fixed list of ints and can be referenced with the variable name NumInputs.
The number of inputs the multiplexer can switch between.
Data Count
This property is of type Unsigned integer and can be referenced with the variable name DataCount.
Number of complete output packets the buffer can store.
Default 1.
Output Mode
This property is of type Fixed list of ints and can be referenced with the variable name OutputMode.
