Component: Median 32 bit (Storage)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Storage
Image Median 32_bit component
Component to calulate the median from a set of sample data. Provides the signal whilst removing any spikes caused by noise or other intermittent data.
AddSample
Adds a sample to the running buffer
ULONG Sample
ReadMedian
This macro has no parameters
ULONG
Simulation macro reference
Data Type
This property is of type Fixed list of ints and can be referenced with the variable name DataType.
Selects if the data is signed or unsigned to allow for correct sorting of the data
Number of Samples
This property is of type Unsigned integer and can be referenced with the variable name NumSamples.
Number of samples to store and sort, ideally no less than 5.
