Component: DMA (CAL) (Peripheral CAL)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Peripheral CAL |
DMA (CAL) component
CAL - Code Abstraction Layer A low level implementation giving direct access to DMA routines.
WriteBuffer32
- ULONG Data
Disable
Disables the DMA channel.
ReadBuffer16
- UINT Data
ReadBuffer8
- BYTE Data
Enable
Initialise the DMA channel ready to process data to or from a peripheral.
The user must enable the corresponding DMA interrupt after initialising the channel.
WriteBuffer16
- UINT Data
WriteBuffer8
- BYTE Data
ReadBuffer32
- ULONG Data
Simulation macro reference
Enabled
This property is of type True or false and can be referenced with the variable name Enabled.
Enables or Disables the DMA component from generating code.
This property is of type Fixed list of ints and can be referenced with the variable name Channel.
DMA Peripheral Channel
Each utilised DMA enabled component should use a unique channel number
Ping Pong
This property is of type True or false and can be referenced with the variable name PingPong.
Controls the ping pong mode.
True - Ping pong enabled, DMA memory double buffered to allow for seamless data sampling
False - Ping pong disabled, DMA memory single buffered
Mode
This property is of type Fixed list of ints and can be referenced with the variable name Mode.
DMA Type
This property is of type Fixed list of ints and can be referenced with the variable name DMAType.
Peripheral
This property is of type Fixed list of ints and can be referenced with the variable name Peripheral.
Size
This property is of type Unsigned integer and can be referenced with the variable name Size.
