Component: Deinterlace (DSP)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Version 1.2 (Release)
Category DSP
Image Deinterlace component
Allows multiple output buffers to be deinterlaced from a single input buffer. Useful for decoding multiple buffer channels sent via communications or storage.
DeinterlaceArray
Repeats the deinterlace function as many times as set in the data count property.
This macro has no parameters
Deinterlace
Outputs a single value to each of the connected output buffers from the input buffer.
Simulation macro reference
Connect To
This property is of type Panel object and can be referenced with the variable name ConnectTo.
Buffer Size 0
This property is of type Unsigned integer and can be referenced with the variable name BuffSize0.
Buffer Type 0
This property is of type Fixed list of ints and can be referenced with the variable name BuffType0.
Buffer Size 1
This property is of type Unsigned integer and can be referenced with the variable name BuffSize1.
Buffer Type 1
This property is of type Fixed list of ints and can be referenced with the variable name BuffType1.
Buffer Size 2
This property is of type Unsigned integer and can be referenced with the variable name BuffSize2.
Buffer Type 2
This property is of type Fixed list of ints and can be referenced with the variable name BuffType2.
Buffer Size 3
This property is of type Unsigned integer and can be referenced with the variable name BuffSize3.
Buffer Type 3
This property is of type Fixed list of ints and can be referenced with the variable name BuffType3.
Buffer Size 4
This property is of type Unsigned integer and can be referenced with the variable name BuffSize4.
Buffer Type 4
This property is of type Fixed list of ints and can be referenced with the variable name BuffType4.
Buffer Size 5
This property is of type Unsigned integer and can be referenced with the variable name BuffSize5.
Buffer Type 5
This property is of type Fixed list of ints and can be referenced with the variable name BuffType5.
Number of Outputs
This property is of type Fixed list of ints and can be referenced with the variable name NumOutputs.
The number of inputs the multiplexer can switch between.
Data Count
This property is of type Unsigned integer and can be referenced with the variable name DataCount.
Number of complete output packets the buffer can store.
Default 1.
Input Mode
This property is of type Fixed list of ints and can be referenced with the variable name InputMode.
